Results 31 to 34 of 34
Thread: Tiguan Trailer Hitch Wiring - Help Needed
  1. #31
    Nov 2022
    Quote Originally Posted by MIG View Post
    My Passat has a 1K0 907 383 F, so the wiring should match.
    Check out page 300 onwards, J345 is the module's name.
    Volkswagen Passat B7 - Wiring Diagrams -vw-passat-b7-wiring-diagrams-eng.pdf
    Many thanks MIG.
    Page 302 seems to be the page I need. J345 (trailer module) to U10 (trailer socket).
    Cable colours match what I have. However, from the diagram, how do I determine which colour is for L turn, R turn etc.?
    Regards,
    Alex V
  2. #32
    Mornington Peninsula, VIC
    U10 is a 13 pin euro style trailer plug.
    It should match this pinout
    13-Polige stekker – TRALERT(R)
    Sent from my SM-N960F using Tapatalk
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  3. #33
    Nov 2022
    Thanks MIG.
    I can now confirm that the wires are hooked up correctly. Strangely, there is still no change in voltage on any of the wires when a turn signal, brake pedal etc. are used.
    When I unplug the trailer module, I receive a 'light' error on the dash. The error disappears when I plug it back in. This, along with the module displaying correctly in VCDS suggests trailer module has been 'coded' correctly.
    I don't have a trailer to test it with, so that is why I am using a multimeter. Which should be fine?
    Any other suggestions?
    Alex V
  4. #34
    I think the unit does a cold-bulb diagnostic to see if the car is connected to the trailer; it tells many other systems in the car what to do while a trailer is attached.
    If you have a test lamp, old school (not LED) or a spare globe lying around, try that; or VCDS\scan tool might have an output test you can try too.
    Might be easier to back it up to someone's trailer and test it ?
