Was looking at these a couple weeks ago, let me know if they fit.
Just placed an order for these ...
Volkswagen Tiguan [Sport & Style] - Wheel arches (1689)
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
Ramee are you looking at putting some 19x10" rims on?
Just wondering why you feel the need for the guard extensions....
2017 Ford Fiesta ST
But then you need to fill them out too. Otherwise they look too much like bolt on guard extensions....
Do they come with the special fixing tape as per the photo?
I tried looking for some other photos of these extensions on a Tig but couldn't find anything else other than their mock-up photo on the net.
Are you looking at getting them painted up? Or just leave them plain?
Be interested in how you go. It looks like they are fitted onto a pre-facelift (2008-2011) Tig in the photo.
I will be going for this sort of look
http://www.vwwatercooled.com.au/foru...d-87730-6.html
But I can't go for that low so I will be running with 18/19 wheels to flush with the guards. I will probably leave them as it is if finishing is ok. But maybe get the side plastics and bumpers painted to match with the looks.
Ok so does that mean there's a new set of wheels coming too?
Good thinking. Given that you haven't lowered it as severely as the APR stage 3+ car you may even be able to run your wheels out to the edge of the flare extensions. Guy ran into rubbing issues with the top of the tyre hitting the underside of the guard (remember it's a big fat block of metal/plastic under there)....
So even though you'll have some nice big flared guards on your Tig you may find you can't can fill them out with wheel/tyre because you'll end up being limited by the existing metal arch which doesn't move. What you probably ought to do is roll the guards but that's not an easy thing to do without some major work to reshape/remanufacture the plastic mouldings too.
I'll be interested to hear how you get on with this project.
If all else fails just get the little extensions that they supply overseas to fit the 19" Savannahs and keep the tyres within the metal. I've been looking at options for mud guards and the little guard extensions but didn't want it to look too fussy.
