Results 1 to 10 of 14
Thread: tiguan recall
    Jul 2005
    tiguan recall
    Anyone got the recall yet? Got mine in the mail the other day, made me laugh a little.
    "A fuse that protects some of the exterior vehicle lights may blow due to thermal overload."
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Adelaide hills, SA
    Not for laugh, it's for real. There are some people that already experienced the problem, and in much deeper sense than what the description of the fault is.
    We have the letter as well, for our 2010 TDI Tig. The 2012 and 2013 should be all good.
    Jul 2005
    just the way that its stated.... a fuse is meant to blow from thermal overload to protect the cabling...
    Yes I got the letter too - though I think my car may have already had the "fix" but will book it in anyway.
    If people aren't registered with VW (second owners) then contact your local VW dealer with your VIN to see if your car is one of those that is effected. I believe this will apply to most of the 2008-2011 cars.
    Quote Originally Posted by blutopless2 View Post
    That is the way fuses are meant to be designed. Much better to blow a fuse than burn out wires.
    I believe the issue is with the fuse holder and not the fuse as such.
    Adelaide hills, SA
    I actually didn't see the blown fuse, just an electrical arcing/burning on the spade of the fuse16 (30A), it is for an onboard supply control unit (the green fuse far left next to the blue one).
    That's right.
    The burning on the bottom spade, the fuse still electrically OK (missed by an autoelectrician ) Removing and reinserting the fuse restored the power to the modules and the car was driveable for 10 minutes.
    May 2013
    sydney
    The fuses melt not blow....
    Jan 2011
    Brisbane - QLD
    So it is the fuse box outside right? I dont want the fuse box inside to blow up
    Got a letter too last week and have booked a time on 31 dec 13.
    Sent from my GT-I9300T using Tapatalk
    MINI Cooper S Clubman - FWD
    Quote Originally Posted by nat225 View Post
    Yep fuse box in the engine bay. Apparently there's a dodgy board and this can overheat. Obviously the 30A fuse can have a fair bit of power running through it and the tracks/board doesn't cope (or is marginal).
    Anyway best to get it replaced before it melts and causes a whole lot of faults in the MFD - see this thread for people that have already had the issue/fuse holder replaced: Faulty Fuse Holder causes Multiple Electrical Fault Messages
    Oct 2009
    Mitchelton, Qld
    Yep, got the letter the other day. But I'm pretty sure ours has already been done as we had the fuse go about a week out of warranty a few years ago. Still booked the car in to get it checked for sure and also get the recall sticker put on it.
