Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Upgrade MIB2 6.5 inch display to 8 inch
    Jan 2007
    Monkeyland
    Quote Originally Posted by hardy_bm View Post
    Thanks for the picture. Looks good, and just saved me from an expensive mistake. So to confirm, we need the A model (aka not the B model) with a button that says 'radio' not 'band'.
    I think the version without a letter at the end is the 'radio' button version, its easy to check with the seller.
    Mar 2014
    Newcastle, NSW
    Quote Originally Posted by monkeysrus View Post
    This is my interpretation too. The one I was looking at was a 5G0 919 606 B with the band button. Lucky escape.
    Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
    Aug 2015
    So now I'm confused...?
    Is it this...
    Quote Originally Posted by VRJ View Post
    Hi there hardy_bm
    The display is just that - only a display and not much more. The heart and brains of the unit sits in the glovebox providing data to the display. A bit like a desktop pc and it's monitor. So firstly, forget about that display on eBay. The equipment you currently have in your glovebox will not work with the 8" display.
    Dean at VW Central in Melbourne is the man to talk to or one of his staff. You have to be careful acquiring a set of these as they need to be coded to Australia or you will end up with nothing more than a brick. I bought mine through Dean, had it installed, which you can do yourself or have someone he will recommend. You can also have the option to have DAB+ (digital radio) added.
    Other than being a satisfied customer, I have no affiliation with VW Central, however they are a sponsor of this site and can be found under sponsors via the main menu.
    Or is it this...
    Yes this works, it's a direct swap and i have done it on my R wagon. Make sure you get right version - i believe the B has a 'band' button instead of 'radio'. (Its the US version) I bought my display from Lithuania. You also need the 5G2819728AHQYI surround. I had VW bring one in for me, cost $255.
    The 6.5" screen has the same resolution (800x600) as the 8". Install takes 15 min. Easy! No coding required.
    VW Golf 7 VII GTD Navigation Display Bedienteil Discover Pro 5G0919606 | eBay
    They can't both be right?
    Sent from my iPhone using Tapatalk Pro
    Jan 2007
    Monkeyland
    The fact that i have done it as have many others might give you a clue!
    Aug 2015
    Yeah that was kinda the point of my post (i.e. aimed at VRJ) as we have one person directing people to a company who will charge a serious amount of money to do what you can do yourself for a lot less Upgrade MIB2 6.5 inch display to 8 inch and claiming it is the only way...Upgrade MIB2 6.5 inch display to 8 inch
    Nov 2009
    Strathfield, Sydney
    Quote Originally Posted by rscott4563 View Post
    Sorry to bring up an old topic however my non facelift my17 golf has 6.5 or 8inch....i cant tell
    Quote Originally Posted by 111 View Post
    6.5inch, Ross. Pretty sure no non-facelift golf 7 has 8inch.
