Page 64 of 65 FirstFirst ... 145462636465 LastLast
Results 631 to 640 of 647
Thread: Summary of Bluetooth Options for RNS510 & RCD510
  1. #631
    Aug 2009
    Melbourne, Vic
    fwiw I don't have those icons either, actually forgot about them when I upgraded.
    Yes they are trivial and it is hardly worth the effort. But I like a challenge and I a know there are others who keenly want a fix. You don't have a copy of your pre upgrade phone module coding in an old scan do you?
  2. #632
    Apr 2010
    The car never came with bluetooth -I retrofitted 9W3 (which didn't have the icons), then swapped with a 9W7, then swapped again for a newer 9W7 when diagnosing issues with my new phone. At no point have I had those icons.
  3. #633
    Jan 2012
    Epping, NSW
    Mine that came with the car does have icons though.
    Will get the long code next time I boot my laptop.
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
  4. #634
    Jan 2012
    Epping, NSW
    Stock bluetooth in MY12 Golf R with RNS510:
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
    Component: TELEFON H09 2730
    Revision: 1B001001 Serial number: 0000766064xxxx
    Coding: 0A01000000010101
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_UHVNA A01015
    ROD: EV_UHVNA_VW36.rod
  5. #635
    Jul 2010
    interesting that - the battery level.
    mine's never displayed it, be it in rsap mode or hfp mode.
    i've got the 9wz bt module.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  6. #636
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by tonymy01 View Post
    Thanks for that tonymy01. I checked the differences between our coding and there is nothing untoward in it. Your language is North American mine is English. You have voice operation inacative, so I set mine the same. You have the three button keypad, I do not. That's about it.
    I did notice measuring block "009 status of phone" on mine is perennially Unknown.
    Summary of Bluetooth Options for RNS510 & RCD510-iphonecapture-001-jpg
    Next time you hook up your VCDS could you PLS take a peek and see if that block is populated in yours? I thought perhaps this block might display a % on yours like the telephone field strength is correctly doing. OTOH it may just be offhook/onhook indication.
  7. #637
    Jan 2012
    Epping, NSW
    Says not connected for mine, even though I know it is...
  8. #638
    Aug 2011
    i have a 9w7 unit and when i first installed it 1.5 years ago it was working perfectly with BT streaming, all icons showing etc on my white mfd and i use an iphone but since upgrading to IOS7, everytime i get a notification on the phone, it will force the headunit to be on BT streaming mode no matter which mode i was in previously (FM, MDI, CD)
    so now when i get in the car and the phone syncs up, i have to unpair the phone under "media" on the mfd which leaves the phone connected but no media available.
    Is there a better way to do this? can the bluetooth module have the software upgraded or something?
    Thanks
    2010 Jetta 125TDi DSG
    1994 Golf VR6 Manual
  9. #639
    Apr 2010
    Have a look in the Settings menu of your head unit for something along the lines of Bluetooth Autoplay
  10. #640
    Apr 2014
    I've got the kufatec fiscon bluetooth module installed in my rns-510 unit but everytime i get a message or unlock my iphone, it pauses the music on the unit. Does anyone else have this issue?
