Thanks Pete. Presumably the 9w7 doesnt foul against the climate control - looks like there's quite a bit of space there.
Hi Fergus,
Yeah I cable tied the 9w7 to the cross brace that is underneath the stereo that separates the stereo 'comparment' from the climate control 'compartment'. And I didn't stick it under the seat because I like the space under the seat, cbf running cables here there and everywhere, and also just thought it was a nice discreet place to put it. You still get good bluetooth connectivity with the bluetooth unit behind the stereo and I haven't had any problems.
Hope that answers your queries.
2008 Mk5 Golf .:R32/ BMP/ RCD-510/ More to come
Went and visited my local VW dealer on the weekend (Werribee), as when I test drove a Jetta there and asked to see the BT in action (before reading this thread) they took me to sit in the service manager's car which was an R36 - and sure enough his MFD read KUFATEC FISCON!
Anyway the gal there showed me a leaflet which showed the BT solution they offer - distributed by AdvancedIce of course. Yep a VW dealer actively spruiking non-OEM products!
Anywho I told her I was after an RCD 510 plus Fiscon and wanted to know how much for them to supply and fit as a starting point.
She said they just had an RCD 510 they'd taken out of a car prior to delivery to fit an RNS 510, and that they would fit it and the BT for $1,600!!! Naturally I asked how quickly I could book it in.
Being an impatient bugger at the best of times I was fully willing to pay $500-$600 (plus probably another $50 each in shipping I'm assuming?) each for the RCD 510 and the BT, and then a further $300 to VW workshop to fit. So you're looking at $1200 minimum plus $300 to fit which comes to $1500 MINIMUM. And not only do I not run any 'risk' of importing, plus having to wait for it to arrive... it will be covered under warranty which I'm pretty happy with.
Booked in for this Saturday (6 November) so will let you know how I go.
How cheap must they have bought the RCD 510 off the customer for, to be able to do the whole lot for $1600??!! I was expecting her to tell me another $500 or so on top of that and was then going to ask how much to fit if I supply the parts.
(PS how lazy/ignorant are people that don't do it themselves and sell it
No, it's one cable.
One cable that goes from the head unit to the BT unit.
If you don't have a pre-installed mic, then yes, you need to run a mic, but you need to do that regardless, and that goes straight to the head unit anyway, so where you mount the BT unit is irrelevant.
Personally, I think under the seat is better as I'm betting the environment in the dash is warmer than under the seat, so less likely to fail. Plus, no chance it'll come loose and rattle around under the seat. But that's me
Oh, and next year, when the super-dooper MY12 BT unit comes out with the built in back scratcher, I can just plug it in and go
Hi Michael,
I wrapeed the cable ties around the unit and didn't put though any specific holes etc.. I tightened them pretty tight so they shouldn't move and there isn't much in the way of horizontal movement that the bluetooth unit can go through when in there (it is pretty snug).
Hope this helps.
Cheers,
Pete
