Results 1 to 10 of 16
Thread: RNS510 help!
    Jun 2023
    Novi Sad
    RNS510 help!
    Hello everyone! I recently got rns510 hw04 and it came with firmware 1100, i tried to install fw 5238 and it failed on hdd part, now i am stuck on enter code screen with my touch not registering and i know it's not the screen that's the issue since ok and cancel buttons on fw upgrade screen register. Tried swl fix and other versions of firmware same thing.. Glad to hear your suggestions! Thanks
    RNS510 help!-rns-2-jpgRNS510 help!-rns-jpg
    Try loading 2680 factory.
    Once that is working load 4120 factory.
    Jun 2023
    Novi Sad
    Hello, thanks for reply. I can not load load older firmware since the 5238 update failed.. I can only load newer fw because Install older fw option in settings is not enabled.. yikes.. what do i do now? it won't take older fw.. do i format hdd?? what are my options since there is no rns service in serbia :'(
    Ah I see.
    Sorry wasn't thinking about that. With Setconfig or similar tool you can enable this without having to go into the menu.
    Jun 2023
    Novi Sad
    is there any way to create setconfig or any other way.. i do not have setconfig noore is it available for purchase in serbia
    Jun 2023
    Novi Sad
    Update:
    Managed to get it in somewhat working state with swl_fix.. Now i can type radio code and touch works but there is no boot logo and sw version is just - .. BUT only if i leave hdd unpluged will the touch work, if i plug hdd back in the dvd drive stops working and touch is not working anymore.. i need to do swl_fix once again with hdd unplugged for it to get back in touch working mode.. Tried enabling fw downgrade in setup and starting varius fw updates(1300, 2760...) and it does not start
    RNS510 help!-screenshot_20230630_200735_gallery-jpg
    Mornington Peninsula, VIC
    Interesting that the unit is stamped with 2xxx firmware, and you said it came with 1100.
    With the issues you are having loading the firmware, maybe the HDD in the unit is failing?
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Pacific Paradise QLD
    You need to burn discs really slowly and use good quality ones Not Princo crap or stuff like that , And not rewriteables
    Jun 2023
    Novi Sad
    the unit actually shows ''-'' as firmware version now, and does not want to take any fw updates(1300, 2720, 2760, 3810..) only the 5238 update by josi then it bricks my unit- prevents from typing radio code
    Jun 2023
    Novi Sad
    Quote Originally Posted by MIG View Post
    hello, thanks for reply, how can i check the hdd, i can connect it to pc and check with hdd sentinel the overall health of hdd, if i buy replacement hdd how do i set it up for use in rns510?
    2.0TDI 172bhp DSG '08 Touran Highline; 18'' AMG alloys; RNS510; Xenon headlights...
