Page 14 of 55 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #131
    Sep 2017
    Yangon
    I have no idea of the history. Normally you should not have to be swapping pins around.
    But you need to do whatever you can to restore communication to the infotainment bus from the CAN gateway.
    Or my CAN gateway version is low?
  2. #132
    If you are installing a discover media that uses address 5f theb you need a newer gateway software but I think 330g uses address 56 radio.
    What if you put your rns back in?
  3. #133
    Sep 2017
    Yangon
    I see. I sold my RNS. Hehe!
    I will try put back original can gateway to see working or not. Will let you know. Thanks!
  4. #134
    Sep 2017
    Yangon
    Quote Originally Posted by Tristanmin View Post
    Changed back to original can gateway and still the same. If I unchecked 56.Radio from can gateway, there is any error on can gateway.
    Now I have no idea why gateway is not talking to Radio if checked in gateway installation list. From other hand, time and temperature are showing correctly on head unit which mean there is communication from gateway to radio. I am very confused.
    Do I need canbus decoder?
  5. #135
    You need to tick address 56 radio. Not untick it.
  6. #136
    Sep 2017
    Yangon
    Yes I understand. What I meant is if with tick, can gateway is throwing the error which is in my previous post.
    But if I untick, there is no error and radio is still showing temperature and time correctly.
  7. #137
    Sounds like there is something wrong with the unit if you can't communicate with it.
  8. #138
    Sep 2017
    Yangon
    Hmmm! I am not quite sure that one since I do not have any friend with VW to test out.
    Thanks kamold!
  9. #139
    Most other reports I have read say that the rcd330 install was a 5 minute plug and play job and it just worked.
  10. #140
    Sep 2017
    Yangon
    Yeah. Mine is working well except OPS and back cam. Both need to activate via VCDS. That is where I stuck. Invested so much on this and nothing is working
