Have you tried another (non-Apple) device to stream Bluetooth audio?
I have a feeling this is an Apple issue, but I could be wrong.
Hi
I've just had an RCD510 replaced with RNS510 in a B7 Passat and everything is working fine except for the audio when playing music from iPhone 4s via Bluetooth connection. The song title/artist displays and appears to be playing but there is no sound. Audio works fine when making/receiving phone calls and for radio and navigation - it is just the bluetooth media that has a problem. Playing music from the phone also works when connected via MDI with cable.
Does anyone have a suggestion on how to fix this?
Wrecking: '97 Golf 3 CL 1.8L - still have motor, panels, and electrics!
DSG Servicing - $260, complete mobile service.
Thanks, Ill try that but the phone was working properly with the RCD510 - this only became a problem once the RNS510 was installed.
Where did you get the rns installed? And how much pls
I've tried it with a non-Apple device and having the same issue.
Does anyone have any other ideas please?
---------- Post added at 06:15 PM ---------- Previous post was at 06:12 PM ----------
I had already purchased the rns & a reversing camera - installation for both around $400 (Marty & fhrx)
It might be a coding issue.
Might just need a tweak of some options within the RNS510's control module with VAS-PC/VCDS.
Just call Marty and ask him, I'm sure he will be happy to help you sort it out.
Hi,
I have exactly this problem with an Iphone 4 and RNS510..
No sound but otherwise songs & artists appear?
Looking forward to anyone who can suggest a fix.
What firmware rev is the RNS running and what version Bluetooth module?
Dino! - www.dinography.com.au | www.autography.com.au
- 2009 VW Passat R36 Wagon | 2009 Mazda MX-5 NC2 Roadster | 1961 VW Split Kombi | 1954 VW Beetle Oval
Hi
I've managed to fix the issue by upgrading the firmware. Was on 2840 and upgraded to 3810 - now working perfectly.
Thanks to everyone for their help and suggestions.
