BoschAutoShop
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Project: Mk3 Golf 1.8t with full dash swap
    coons88's Avatar
    coons88 is offline Volkswagen Fan
    Jun 2009
    Auckland, New Zealand
    Well two things I will highlight first, unfortunately this car is NZ so not part of your scene per say, but part of the down under scene for sure!
    Secondly, strap yourself in because this thread is about to deliver from start to finish..
    Before I get into I'll do some shameless whoring and show off the old whip - a few of the parts were donated before I sold it to go onto the new beast.
    Right, so this is my project I completed earlier this year. I 'accidentally' bought a 1.8t for a bit of a bargin, so then I thought well **** I need to do something with it now! I'm a Mk3 fan boy, and the requirement was a 3 door shell with sunroof. Very hard to find! I ended up buying a tired old VR6 of my mate which became my base.
    I bought the car around the middle of last year and I planned to start the build in November. In the intrum I was just gathering all my parts...
    That was all well and good until one night the car did it's crack pipe and dropped all it's water. The coolant light used to flash anyway so I just always ignored it, nek minnit, overheated seized VR6. At first I was pretty bummed because I had a buyer lined up for the motor/box for $1500. Anyway long story short there I somehow managed to swing a sale with some random guy who still bought the package for $1500! **** couldn't complain there haha. I guess the gear box was what was really worth the money though, not the engine.
    So anyway fast forward to November. I had collected pretty much everything I needed and it was time to get this show on the road! The plan was to bang it out in 4 months and have it on the road by the end of Feb in time to make a pretty big show me and a few others organise annually called SO - check it out and like us on FB - SO 2012 | Facebook
    In reality it went a wee bit over and it was finished mid March, still pretty impressive though. I'll make the show next year..
    Before I bust into then I better breifly outline what the plan was:
    - Full respray in Candy White, along with face lifted trim spec
    - 1.8t, full Mk4 dash and loom swap
    - Fully retrimmed interior, new head liner (black), trim all the pillars as well (black), retrimmed Mk3 Recaro seats
    - Sitting squat on H&R coil overs and BBS Pininfirna wheels (to begin with anyway)
    - and a crap load more!
    The platform
    The power plant. It has a KO3s fitted also
    The dash and associated bits
    Mk3 Golf - 1.8t
    Suzuki GSX250
    coons88's Avatar
    Jun 2009
    Let's go then!
    The car loaded with the engine temporarily bolted into it's new home as it all get's transported to my mate Johns who was doing the fabrication work
    Meanwhile I got going on some minor bits and pieces I could still do at home
    Mk4 under bonnet washer jets
    Back in the 'John's chop shop' work plowed on
    Running a Mk4 ABS pump
    Had to modify the tunnel a bit to make the full center console fit in, but the end result is superb. OEM+!
    Mk3 Golf - 1.8t
    Suzuki GSX250
    coons88's Avatar
    Jun 2009
    Audi door handles
    With that fab up was finished and it was transported once again to another mate who's a painter, onto the painful task of paint prep
    First of the colour laid! By this stage to give you an idea of dates we are around mid December
    Mk3 Golf - 1.8t
    Suzuki GSX250
    coons88's Avatar
    Jun 2009
    Inside and engine bay finished, outside still in primer awaiting final block work
    A week or so later (a couple of days after Christmas) it was into the booth for paint
    Transported back to his garage later that day, oosh it was good to see it out in the sun for the first time!
    It stayed there for another week or so as we did some finishing work on it
    Early Jan it was on the move again back to my mate John's workshop (who did the fabrication) where most of the install work was carried out
    Glass in
    Loom, brake lines, ABS pump in
    Rebar, pedal box, heater box all in
    The donk in! Turning the key was only a day or so later. At this stage we're getting into late Jan
    Suspension and brakes in and test fitting the wheels. Starting to put the trim/lights/bumpers on
    Mmmm I was starting to get pretty excited at this point!
    Perfect!
    The alignment was out to what on the front hence the poke. Engine bay coming along
    The interior stayed looking like this for quite a while as I pottered away on the wiring. Had to merge the Mk3 loom into the Mk4 loom at the B pillar. Also had to figure out the best way to wire in the Mk3 sunroof, the mirrors, the fuel pump, the windows, and the central locking
    The setup I went with on the windows; I used a Mk4 window control module which drives the Mk3 motor as a slave. So it plugs in as per normal, and as far as the car is concerned it is just running a normal Mk4 window. We even programmed in the auto roll up feature from the keyfob . Oh, which reminds me - the OEM keyfob all works as per usual. I refitted the Mk3 locks and vacuum system, and I tapped the pump into the Mk4 CCM. Works a treat
    Mk3 Golf - 1.8t
    Suzuki GSX250
    coons88's Avatar
    Jun 2009
    This shot summed up the wiring situation pretty well! John and I studying Bentley manuals at the top there
    Exterior really starting to come together now
    Meanwhile, not too much going on here
    I de-crubbered the dash bits and repainted it in saturn black. It's like new again
    Pretty much finished in here now. There was actually quite some issues fitting in the head lights it was so cramped! Had to take them back out and modify the casing a wee bit
    The IC fitted in
    It came back on a tow truck to my house where I drove it for the first time from the road into my garage. Insignificant, but enough to but a big grin on my face. Noisy as feck too, still no exhaust. Would have been mid to late Feb by now
    Starting to come together inside now..
    Got my mate Doug around and we head a headliner day/night. Redid the headlinder along with wrapping all the pillars. I used that really nice stippled material like you find in the new Mk5/6's etc
    Interior fit out really coming together now
    It was pretty much finished in here now, the seats were still away at the trimmers at this stage. It took me another week or so before I finally cracked how to make the Mk3 switch operate the windows properly. I also scored a Bora sports cluster
    85psi to pop these suckers
    Took it for it's first test drive to the tyre shop to get the wheels on and an alignment. Super happy with the final wheel and tyre fitment. Early to mid March here
    I modified the Mk3 mirror and installed some W8 style dome lights in it, makes a super nice atmosphere at night. I pulled open the Mk3 window switches and sunroof switch and swapped the LED's to red too
    Mk3 Golf - 1.8t
    Suzuki GSX250
    coons88's Avatar
    Jun 2009
    And here it was, unveiled so to speak at a club meet we had at the end of March. We all went on a bit of a drive out west, bloody good fun to get it out on the road There was a bit of a hold up on the seats and I didn't get them back until a couple of days before this! Oh man that new leather smell, so lush!! That meant I ouldn't legally get it reregistered etc until I had them too, so it was a mad dash during the last week.
    Did I mention I added heating elements to the seats!? Details....
    The Dub life.. wax on wax off
    Interior finally finished, my R32 trim kit arrived after a massive debacle there..
    Oh dear, "I declare this project finished" Nek minnit.......
    The heater box was not working, I realised this was because the loom was a climatronic loom. I initially decided to just rewire it to power the manual HVAC controls, but I had a climatronic box offered to me so I thought, **** why not! I took the chance to replace the air vents too with the classier Bora vents
    Everything is fully functional too; the Mk4 telescopic steering column, the ash tray, the glove box, the air bags, the warning lights, the MFA display, etc etc etc
    And here she sits now, taken at an event I was at over the weekend. I'm still waiting on some black hoses to replace the ugly blue ones. Once those are replaced it will look stealth as
    So how is she? F'ing awesome! I got my ECU chipped my Stealth Racing in the UK (super good guys to deal with!). It rips! But it's also really good to drive around normally. The gear box ratio's (Mk3 GTI 02A) along with wheel/tyre size have worked out really well, sits at 2.5k at 100kmph. Super economical, can comfortably drop it in the 5's (L/100km).
    Totally loving it!
    What's next? Well I want to split and refurb my SSR Reverse Mesh wheels that I had on my old ride. I want to rebuild them to 8.5 and 9".
    I thought the door cards looked pretty mint, but then I put the seats in and they don't look so mint anymore lol. So I think I will look at getting them retrimmed too later in the year. A few other minor bits and pieces I want to do too, but all in time!
    Hope you enjoyed the show!
    Mk3 Golf - 1.8t
    Suzuki GSX250
    whiteVR6's Avatar
    whiteVR6 is offline Volkswagen Enthusiast
    Dec 2007
    Girraween
    Epic thread
    Pity not many mk3 projects like this in Aus
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
    noone's Avatar
    noone is offline Damned BlueCollar Tweaker
    Jan 2009
    blankedy
    Nice work dude, great to see the passion that went into this toy
    Stiggy_21 is offline Volkswagen Enthusiast
    Dec 2008
    Bentleigh, Melbourne
    thats a sweet conversion, congrats!!
    to bad your not in Aus
    '76 Golf LS Swallowtail 4dr
    '76 Golf Swallowtail 2dr
    '89 Golf GTI 16V 2dr
    gecko2k's Avatar
    gecko2k is offline Volkswagen Fan
    qld
    sweet dude! Lookin' good!
