Results 11 to 20 of 30
Thread: Mk3 8v Crossflow
    Sep 2006
    West Sydney
    Quote Originally Posted by Water Boy View Post
    Thats interesting that a non-cross flow head has the same inlet bolt up pattern as a cross flow head.
    I meant they use the same manifold as the AEG.
    Sep 2007
    This is an ABA inlet manifold. It has mounting holes on the top and bottom of the runners.
    This is a mk2 8v counter-flow inlet manifold. All of the counterflow heads have the same runner spacing and manifold bolt provisions.
    These are not interchangable. The ABA, i believe, uses a US specific head, with a similar bottom end as the AGG motor. The early ABAs apparently came with squirters for pistons and the late model ones didn't. There are different schools of thought on their necessity but many are adament that they're really quite useful.
    A common conversion in the states is the ABA 16v motor. They never got the 2.0 16v ABF motor domestically, and there are probably millions of 2.0 8v engines that can be had for pennies. The block heights (aussie 2.0 8v and ABA) are the same, which are different to pretty much every other 8v, as is rod length. The change the pistons and use any 16v head (PL heads are common as **** in the states) = effectively 2.0 16v ABF. It's a lot cheaper to send pistons from europe than it is short motors.
    Basically, they make 16v motors with their block and older CIS heads. You could do this just as easily, but it's not nearly as cost effective because 16v motors/heads here, are sufficiently rare too.
    87' MK2 GTI
    13' MK7 TDI
    Aug 2006
    Melbourne VIC
    Thanks for that info Jay.
    I thin im pretty determind to get a crossflow head onto a 2e block. (How I will find out)
    Aug 2006
    Melbourne VIC
    Been doing some more reading:
    Only real mod to use it on the older type blocks is to reduce the oval oil channel to a smaller round one after which the 2E style head gasket works fine.
    Aug 2006
    Melbourne VIC
    Aug 2006
    Melbourne VIC
    Sep 2007
    om nom nom nom.
    nice set ups. oh how i wish i spent money on a cross flow... so much more space!!
    so is it cross flow that you want? or itbs? i have a sneaky counterflow itb project... in my mind.
    87' MK2 GTI
    13' MK7 TDI
    Boronia VIC
    There's a set of ABA TWM ITBs going cheap on the 'tex at the moment..
    http://forums.vwvortex.com/showthread.php?5010378-2.0-8valve-TWM-itb-s-BAND-NEW!
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Sep 2006
    West Sydney
    Those engines look ****in' beautiful. I can really appreciate engine detailing now that I've got mine up on a stand and it looks like it's been shat out by bigfoot.
    Aug 2006
    Melbourne VIC
    Pete thats naughty but so fine...
