Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 168
Thread: mk2 GTI Track Toy Project
    AusScare's Avatar
    AusScare is offline Volkswagen Fanatic
    Mar 2008
    Hey all,
    I've been looking for a car to throw money at, but didn't want to put it into the Peugeot because the community and tuning in Aus is pretty average. So the only answer was to get another VW! I like the 206 as a daily though and didn't want to get rid of it, so I went and bought a mk2 Golf GTI, went halves with my mate Olly (also a member on here).
    Picked it up this morning, took it back to his place, drove it round the back streets, drives really well! A few areas need a bit of attention, but that's fine. Washed it, cleaned out it's new home, parked it, started stripping it!
    Plan is to strip it down, fix (and upgrade) the vital bits, then get it ready to take to the track. Thing is we are on a tiny budget, so thinking just the basics to start with, strip it down, brakes, track rims/tyres. All costs will be halved though which is a bonus.
    It won't be road registered for now. So we'll both be looking up what is the best to buy in terms of race related bits and pieces, so feel free to add your input/wisdom!
    Pics of course:
    So yeah, that's about it, going to take it apart, make a list of what needs to be done, and go from there.
    Feels good to have another vdub.
    Tim
    GoLfMan's Avatar
    GoLfMan is offline VWwA Clown VWwA Super Moderator
    looking good dude!
    I'd be doing suspension and brakes first, then engine. (Put carbs on it and get rid of that horrible digifant!)
    Jarred's Avatar
    Jarred is offline Dub Crazy
    Jun 2007
    Eastern Suburbs Melbourne
    Nice one. should be a neat little project.
    If it were me, this is what I'd look at doing, a nice combo between performance and BFYB.
    (keeping in mind i've based it on track use only)
    -fix all the mechanical things. Body work and stuff not so important. As long as it's all 100% mechanically. (do first, the rest no particular order)
    -mk 3 2.0 front brakes. These are 256mm, and you need the hub as well. Get some nice discs and good pads (ie, greenstuff, and good fluid)
    -mk 3 2.0 Exhaust header. get rid of that toilet bowl exhaust that's standard, with the mk 3 option, it's cheap and easy. Then finish off the rest with a 2.25" or 2.5" system.
    -semi slicks. (or just really good rubber) stay with 14" ones, as they're cheaper than 15's. 256mm brakes fit under 14" wheels too.
    -harness, seat etc. mk 2 gti seats are OK, but a proper bucket seat will actually hold you in the seat, rather than have you sliding about the cabin.
    -an aftermarket cam & ebay chip should pick up the performance a bit, reasonably cheap too but I'd rather spend the cash on the next option (first atleast)
    -suspension. good cup kit. koni adjustables and some 60mm springs probably. Look on ECS website, they're mighty cheap there and shipping isn't too bad either!
    maybe one day down the track an ABF 16V, but i think we're dreaming now!
    make sure you have a look through Pete Jones' wreck to race thread (the white 4 door) he's got heaps of info in there about setting a car up to get it ready for some track work, on a budget too!
    anyways, hopefully that's some food for thought!
    i like volkswagens
    Peter Jones's Avatar
    Peter Jones is online now Super Moderator VWwA Super Moderator
    Boronia VIC
    The biggest single performance improvement you will get is from learning to drive.
    Find local clubs that do familiarisation and instruction sessions.
    Don't go all out throwing money at it until you've taken it around a track at least once.
    Assuming the car is mostly functional, tyres would be my first upgrade, nothing else in the car works without them.
    Semi slicks are the way to go, Toyo R888 or Yokohama Advans. They don't wear as fast as you'd think I've got about 2 years out of a set.
    After you've got the tyres, you'll need a seat and harness.
    Reliability is key too, tie back every loose wire, fix every oil leak, replace every water hose, replace the wheel bearings, there just can't be any loose ends anywhere on the car.
    In order to win a race, you must be able to finish it.
    Following on from that you can prioritise the upgrades form there Brakes, gearbox and suspension obviously being the big ones.
    I'd leave the motor till last, get fast with what you've got then add the horsepower. Do the minor stuff like the exhaust mod along the way but try to think ahead a few steps so you're not spending money twice.
    Shout out if you've got any questions and take a wander through my wreck to race thread, there's a lot of things I've learnt in there that might save you some time.
    Best of luck on the track, I'm looking forward to seeing the project develop.
    Pete
    79 B1 Passat Dasher Project
    12 Amarok
    AusScare's Avatar
    Mar 2008
    Thanks for the replies guys, all good info! I'm going to have a read of Pete's thread, a proper read, not just a skim read, of all 77 pages.
    Brakes are definitely on the cards to replace, the previous owner said something was wrong with them, so we'll have to take them apart. The 256mm disc upgrade also sounds good, I'll have to start a wtb thread to source the supporting mods for that.
    Reliability is definitely the main priority, so we'll start with a full service, see what needs attention, replace anything that's worn, I think a few things are gaffer taped together so that'll need to be sorted.
    In regards to tyres, current stock rims are 14x6 iirc, and they will fit max 185's? Should we be looking to get some 14x6.5's so that a 205 tread will fit?
    I'm happy to stay at 14" as well, means can get nice and low and still be all function over form.
    Boronia VIC
    I'm running 185/60/14 semi slicks. They're about the cheapest size and perfect for a Golf. I'd stick with the wheels you've got. Saves a lot of clearance issues and mucking about.
    Too much tyre and you won't get it up to temp, especially on short events like hill climbs and sprints.
    Semi slicks are much better tyres than road tyres, there's no comparison, you'll be amazed at how fast you can get 'round a corner.
    12 Amarok
    AusScare's Avatar
    Mar 2008
    That sounds perfect. What sort of pricing is it per tyre, what psi (cold) do you run on track days, where do you buy the tyres from? Does the tyre deteriorate badly if the car is just sitting there for 6 months at a time?
    Boronia VIC
    At that size they cost me about $213 each from memory.
    I have two sets, one set I bought brand new and the the other set I got second hand off e-bay.
    Motor sports suppliers are the way to go. Go to a couple of race meets and ask around would be the best way. There were at least 6 different tyre shops on site at the Sandown historics this weekend.
    If you weren't going to run them for 6 months at a time I'd store them off the car out of the light. Just so they don't go square or get UV damaged.
    A couple of laps soon gets them scrubbed back in.
    I run the tyre pressures at 23 PSI cold. You get a user guide with Toyo semi slicks that explains how to set all of that up. Proxes R888
    It sounds low but these tyres have belted sidewalls and the pressure increases as the tyre gets hotter. 23 PSI is the manufacturers recommended cold setting for the weight of my car and the type of racing I do.
    12 Amarok
    Back Door Shenanigans.'s Avatar
    Back Door Shenanigans. is offline Volkswagen Enthusiast
    Mar 2010
    Lesmurdie
    Haha saw this on ocau. Looks good always wanted a mk1 as a track/drag car but can't afford it at the moment. Keep this updated very interested
    2001 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff :( | Slowly building it up | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Coxy09's Avatar
    Coxy09 is offline Volkswagen Fan
    Nov 2008
    Ahh Peter Jones, you read my mind! If people would learn how to start, stop and go around corners first without worrying about the power there would be a lot more quicker people out there! I get this everywhere and from everyone I talk to, my first thing with a car is to make sure its mech ok, then do brakes, shocks, tyres first. Then once that stuff is sorted out, worry about the power. Power doesnt make you quick, after all, Michael Shuey would be able to keep up with me if he was in a R32 and I was in a Gumpert say....comes down to the driver!
    Coxy
    "Some people dream of achieving greatness, other people get out of bed and do it"
