BoschAutoShop
Page 18 of 23 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 222
Thread: MK1 Caddy R32 4 Motion
  1. #171
    Dub Toffee's Avatar
    Dub Toffee is offline Volkswagen Fan
    Sydney NSW
    In relation to the rear turbo mounting.
    Are you meaning at the rear diff?
    If So, there's a mob in the states that have done it to a few corvettes and vipers as well, videos are all over YouTube.
    still havnt looked them up yet
    Quote Originally Posted by thestu View Post
    Rear turbo would be great! Its already under vacuum so there wouldn't be any more lag! There are a few 2.4 v6 audis that use rear mounted turbos because the engine bay is way too crampted.
    well i have room in their but I'm not after a drag strip car so maybe i can live with a turbo under the tray and have a cleaner engine bay
    Quote Originally Posted by alex g View Post
    Love the die bro, lot of work there , please tell me you broke out more tools than the grinder, although there's not much that can't be done with a fist full of 1mm blades and a flapper, looks awesome.
    Can't wait to see the forming end of the bender, let me know if you need anything.
    Have been meaning to get back to you re dropping over its just been hectic of late.
    thanks for the photos mate!
    haha yea got to love the old grinder and fist full of disc method lol
    nothing like doin time on the grinder
    i am now looking for the right Ram to drive the Die around.
    might need someone who has a lathe handy soon
    i have to make a cut in the main drive shaft close to the cv joint
    measure the inner diameter of the tube and lathe up a small section of tube to fit inside
    that will allow me to extend the main driveshaft.
    Well got under the Caddy today to take a look at some measurements
    busted out the old laser it comes in handy!
    Figured out a reasonable way to get perpendicular with he shaft on the dif and gearbox.
    found out that i got the front aligned nicely and horizontal with the chassis
    but the rear diff is out by maybe 5deg.
    I have to get that sorted to have an alignment that is as close to being on the same centre line as is possible
    without having Audis technology.
    was toying with the idea of having 2 cv joints in the middle of the shaft that would make things easier
    but then more variables to worry about if i get any vibration noises.
    but boy this little thing to roll around on made an Awesome difference!!
  2. #172
    Preen59's Avatar
    Preen59 is offline Ultimate Dubber
    Jun 2006
    Orange NSW
    Looking good, dude! Moar pics needed.
    My lathe can swing 15 inch diameter if you need something done.
    APR Tuned | KW Suspension | Weitec Suspension | INA Engineering | Mocal Oil Control |
  3. #173
    BonsaiTiger's Avatar
    BonsaiTiger is offline Volkswagen Fan
    Jan 2012
    Hamilton, QLD
    Just tuned in to this thread, what a project! No updates for a month or so though? Dying to see more pics of it!
    # 76 Mk1 16v In Progress # 2011 6R Polo GTI *Sorely Missed* :(
  4. #174
    Dub Toffee's Avatar
    Sydney NSW
    Cheers mate just prioritizing a few things around.
    Funds and direction etc.
    I have looked at different exhaust options
    And will soon be building stainless exhausts for GTI and the caddy.
    I feel that I need to get this engine started so as to hear it and just get excited.... It will help alot
    To gain momentum again
    So it's
    - get sleeve for driveshaft
    -Align rear diff with front transmission
    -Install driveshaft for fitting later get balanced
    -Fabricate exhaust leaving room for fuel tank
    Couple other little jobs and Go for Start your engines baby
    Finish up front assembly
    Etc etc
    If Anyones Wondering I Turfed my home made bender
    And got a
    Pro Tools 105 HD
  5. #175
    mikinoz's Avatar
    mikinoz is offline Super Moderator VWwA Super Moderator
    Jul 2005
    Blue Mountains
    Quote Originally Posted by Dub Toffee View Post
    And got a
    Pro Tools 105 HD
    When I need my exhaust and roll cage I know I can call on you and Al to deliver the goods now!
    Keep a steady pace Ben, keep plugging away - I am looking forward to more updates.
    Kaninchen weiß - The Chameleon
    Quote Originally Posted by Rigo
    You must be friends with a genie or something...it's unreal how you get so many awesome things!"
  6. #176
    Dub Toffee's Avatar
    Sydney NSW
    Update.
    Kind of Freaky but i did put a fair amount of time into getting the engine sitting parallel with the chassis
    using Bently measurements but,,, Since getting extensive Caroliner measurements and measuring the output on the gearbox for the
    front to rear driveshaft its damn near perfectly parallel and centred!
    this is good news for me because i only have to focus now on the rear which was off by about 6 deg.
    Unfortunalty i didn't have enough play in the frame to turn it true even with my modified bolts that are based of original Vag 10mm bolts.
    Anyway its a challenge. So their is a plan in the works and its well underway.
    New jack stand that i have made for the rear of the Caddy.
    this is helping me to set the chassis of the caddy level
    and about 700mm of the ground whilst i work under their and get all my measuring and setting done.
    Modified Bolt x4 used for mounting haldex frame
    Thanks to Bret an industrial electrician at work i know who is also handy on the Lathe
    Previous spacers drilled out and now being replaced so as to get perfect as practicable alignment.
    new Spacers 50/50/20mm now mounted underside of space frame tags.
    As the haldex unit already was sitting quite high of the ground i could afford to lower it
    and make my job of repositioning the frame easier.
    ok This is cool.
    Big thanks to Al who swung this piece of seamless tube on his trusty Lathe.
    Glad to have your mark on the Caddy mate.
    This Tube will be used to lengthen the main driveshaft all of which I'm preparing for now.
  7. #177
    mikinoz's Avatar
    Jul 2005
    Blue Mountains
    This is all good news bro!
  8. #178
    Preen59's Avatar
    Jun 2006
    Orange NSW
    Looking superb, mate.
    Sorry I never had the time to do that tube. I haven't even got time to do the stuff I'm getting paid for at the moment! haha.
  9. #179
    KI11Z's Avatar
    KI11Z is offline Volkswagenist
    Sep 2006
    Parkinson / Brisbane
    Whollywhathefk...... my man, you're insane! I love it! i'm so envious of your fabrication skills, planning and foresight! Hands down the coolest thing i've seen in a while, very inspirational.......Keep doing work son!
  10. #180
    Dub Toffee's Avatar
    Sydney NSW
    HAHA I miss the way Queenslanders Talk!! ;-D
    No Wories Preeny thanks for even considering to help mate, i know your busy and so good luck
    with your responsibilities mate!
    The beginnings of a chassis JIG.
    Using the caroliner measuring points on the chassis of the caddy
    a JIG can be made to align perfectly with the chassis on varying planes
    verticle and horizontal.
    From these alignments I can make a permanent centreline and measure out from this to set the wheel base more accurately
    as well as align the engine gearbox output and rear haldex unit.
