Results 1 to 5 of 5
Thread: SEAT Cordoba GLX 95
    Feb 2007
    Mount Evelyn
    SEAT Cordoba GLX 95
    Just wondering if anyone has had trouble with the fan switch only working on speeds 2 & 4 and aircon - normal switch does not appear to return to off position - any ideas how to tackle this, I have Haynes manual which really does not explain how to check or eliminate those types of faults.
    Camden, Sydney
    Yeah the fan switches play up on the Seats and Golf 3s.
    Changing it is the easiest fix. I have some in stock if required. PM me.
    Or just use speeds 2 and 4
    Jul 2007
    Bondi
    I too am having fan issues on my '95 Ibiza. Unfortunately, none of the fan settings work, and this morning, i started to get smoke from the vents, and a distinct smell of burnt toast!
    Either i have a toaster under the hood, or there's a bigger problem. I'm thinking electrical burn out of some sort.
    Anyone got an idea or some advice?
    Jon......
    Camden, Sydney
    Probably the switch also. You could take the glovebox out and apply power to the fan.
    If that works its the switch.
    Jul 2007
    Bondi
    Thanks for the advice. I wasn't sure where the fan or switch was located so i'll check that out. Are you able to get the parts for this?
    Jon...
