Results 1 to 5 of 5
Thread: Mk3 coil packs>.
    Anonymous Guest
    Mk3 coil packs>.
    Factory problem???/ or just faulty coil packs?? they all seem to crap themselves sumwhere along the line..
    Camden, Sydney
    They all do it. You can also replace with a Seat Cordoba cheaper one if you can find one.
    Apr 2006
    Nth of Nowra.
    coils
    Coil pack or "T"coil, both crack with age, Should change every 6 to 8 years.
    To test if there on the way out (if no obvious cracks have formed yet) simply spray a fine mist of water on outside of coil @ idle. Water will enter the fine cracks & short out coil. Then you'll need to dry out coil, to be able to re-start engine.
    Camden, Sydney
    You can araldite em up short term.
    Camden, Sydney
    Check this out for repairing VR6 Coilpacks
    http://www.gti-vr6.net/library/engin....8L_coil_pack/
Similar Threads
  1. Coil Over / Spring and Damper discussion
    By Hilton_K in forum Mk5 Golf & Jetta
    Last Post: 08-08-2007, 12:31 PM
  2. Mysterious Intermititant misfire. :?
    By ScienceVR6 in forum Mk3 Golf & Vento
    Last Post: 19-02-2007, 07:28 PM
  3. Coil binding
    By DubSteve in forum Mk3 Golf & Vento
    Last Post: 07-11-2006, 02:20 PM
