why'd you needed to replace your reservoir anyway. I was onced advised by a well known professional that I needed to replace mine. the replacement didn't even fix my initial problem in the first place.
From the US mate, at importpartsconnection. Really cheap there but if u get it, make sure u get the radiator cap too. My old one is really tight to put on and take off
Coz it was full of muck?? The old one still functions properly but when its so dirty that u cant see ur water level i think its time for a new one. You also cant take apart a reservoir and clean it which is the down side.
U cant clean it? why not?
Good work Pedro. Nice to see some factual info on here. Good write up. Well done.
how to remove the splash guard?
does the thermostat housing has o-ring?
will this thermostat fit?
New Coolant Thermostat 87 deg + Ring for VW Beetle Jetta Passat Golf 044121113 | eBay
or this
https://au.vwheritage.com/termostato-87-102
