Results 1 to 5 of 5
Thread: Clutch / brake problem vr6
    Burnie is offline New Dubber
    Jul 2010
    Pialligo ACT
    Hi my clutch pedal has recently felt like its loosing a lot of pressure especially in the morning . It has a slow leak and iv been topping up the brake fluid and it seems to fix the problem slightly . Today it lost all pressure and I couldn't change gears so I filled it up again, pumped the pedal a couple of times then started it up and this really loud hissing noise was coming out just above the brake pedal in the cabin, sounds like a vacume leak . The noise would only disapear if you step on the brakes or accelerate . The clutch pedal still has not much pressure but the bakes are working fine , just wondering If anyone knows what this might be ?
    Thanks
    Umai Naa!! is offline Volkswagen Fanatic
    Dec 2008
    Sydney/Canberra
    Could be a combination of the booster and the mastercylinder failing.
    I'm not that far away from you, if you want me to come have a look at it. PM me if you like.
    Wrecking: '97 Golf 3 CL 1.8L - still have motor, panels, and electrics!
    DSG Servicing - $260, complete mobile service.
    Jul 2010
    Pialligo ACT
    Thanks for the offer but I am up in the Blue Mountains at the moment. The mastercylinder was replaced a few months ago so maybe its the booster.
    Dec 2008
    Sydney/Canberra
    Ah ok, no worries.
    If you need a booster, I've got one here that I'm about to pull out of a car.
    Jul 2010
    Pialligo ACT
    Thanks, I will see if I can get someone to have a look at it up here and pin point the problem.
