Results 1 to 3 of 3
Thread: Vw mk2 abf
    Jul 2016
    Vw mk2 abf
    Hi all
    After using all ofiginal vw mk2 8v gti engine mounts and brackets on my new abf engine i ran in to a clearance issue. Rear driver side of the engine is sitting high and bonnet wont close. Sould i use g60 rear mount? Wpuld that fix the issue?
    Thx
    The ABF is 16mm taller than the 1.8 GTI motor so you'll need to compensate by that much.
    There's a few MK2's running around with ABF's so hopefully one of the guys will be able to point you in the right direction. If not, go here - Mk2
    Paul
    Mar 2014
    Just use mk3 subframe with rear engine mount and mk3 rear bracket. You will have to use mk2 control arms.
