BoschAutoShop
Results 1 to 10 of 14
Thread: 3 piece wheel screws!!
    byza is offline Volkswagen Fan
    Dec 2008
    Gold Coast, Queensland
    Looking for some help from guys who have rebuilt 3 piece wheels...
    i am in the process of sorting out a rebuild on a set of rims for my MKV and the existing bolts are in pretty good nick but looking at going gold bolts instead...
    anyone have any contacts to purchase whell screws in Australia? there is a couple of shops in the states and UK but like supporting locals in the first instance...
    i am chasing same bolts as BBS Rs screws... specs M7x32mm 12.9 head...
    does anyone know if the nuts on the inner side of the wheel can be reused and ideas where to buy the sockets to disasmble with rims?
    anyone with any help would be appreciated..
    thanks
    Lorenz's Avatar
    Lorenz is offline Sponsor VWwA Super Moderator
    PM intensem1 (Alex) I am sure he will be able to point you in the right direction (bolts and tools), he has rebuilt quite a few sets of BBS.
    What wheels are your rebuilding?
    (my 1000th post woo )
    SLAMMEDdistribution - for all your suspension needs
    Dec 2008
    cheers mate... i might give him a pm...
    iphone pic.. colored centre and gold bolts, polished lips... some will hate but i dont mind...
    Lorenz's Avatar
    They look dope mate, 5x114.3 with wobble bolts to fit?
    Old school Work/Volk wheels?
    Dec 2008
    old skool work rezax's... yeah they are 5x114.3... should be good for resale but not wide enough.. only 18x7.5 right now but would like to get wider barrels eventually but will refinish faces etc first and widen later i think...
    thanks mate
    Lorenz's Avatar
    They should look pretty nice fitted up, what offsets? You running adapters or wobble bolts to fit those?
    rayray086's Avatar
    rayray086 is offline Super Moderator VWwA Super Moderator
    Sep 2006
    West Sydney
    I've thought of going to a local fastener shop and see if I could get some custom-made. I'm guessing most wheel shops would do the same too. I'm in the same predicament with some multi-piece wheel bolts too - would like to get new ones in a different colour.
    As for the tools, any dedicated tool specialist should carry what you're looking for. What I did was bring a wheel in and ask for the correct socket/bits that match up with them. If the wheel bolt/nut are 12-point, get 12-point sockets. Don't leg it with hex sockets. Most shops should have whatever you need in stock, it's only the weird 10-point bolts that O.Z. Racing wheels use in some of their wheels that's ridiculously hard to find. If the bolts on the Work Rezaks are the exact same as BBS RS, then you'll be needing a 12-point 8mm socket for the bolts, and a 12-point 10mm socket for the nuts.
    You can re-use both the bolt and nuts provided the thread is not stripped. Some don't recommend re-using them but many others have with success - just use some blue Locktite and torque them down to ~24 ft lbs. Make sure you bolt them on in a criss-cross pattern.
    Past: Mk3 Golf 2.0L 8V RIP
    Present: Audi 8L A3T
    WABIT's Avatar
    WABIT is offline Volkswagenist
    Nov 2005
    just get them gold plated, would be cheaper than new bolts
    dom
    South East Dub Fest, Australia's V.A.G Watercooled Car Festival!
    http://www.facebook.com/sedf.melbourne
    Dacri Media, Like Us On Facebook! Dacri Media
    Mr. JLT's Avatar
    Mr. JLT is offline Volkswagen Fan
    Townsvegas QLD
    Im rebuilding a few sets of wheels atm. This may help
    http://www.prestigewheel.com/Imagepwa990028.asp
    Also check ebay-http://cgi.ebay.com/ebaymotors/BBS-GOLD-WHEEL-BOLTS-SCREWS-RM-split-rims-120-pc-NEW_W0QQcmdZViewItemQQhashZitem518e727c54QQitemZ35 0282218580QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAcce ssories
    I found some good wheel harware for BBS and RH wheels. Im looking for HRE wheel hardware now and the place above has them.
    Cheers J
    SLAM.POKE.TUCK.DROP.DOPE!
    Bboy_Sparx's Avatar
    Bboy_Sparx is offline Volkswagen Fan
    Sep 2006
    I feel the pain. I went to buy new bolts for mine, but it was such a hassle that I ended up just polishing mine. 30 bolts per wheel
