Results 1 to 9 of 9
Thread: Pumpe Duse to CR , what was the difference
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Guys , GF got her mind set on an EOS , had a look at one today 2008 TDI model 90,000ks , perfect VW dealer service record ,
    recent cam belt change as well .
    But when I started it it sounded louder than my Jetta Pumpe Duce model and it also ran not as smooth as mine.
    Now I thought the CR TDI was to be quieter and smoother. this thing actually was causing small vibration throughout the front of car.
    Any comments.
    Apr 2008
    How certain are you that 2008 EOS was CR?
    The CR came in with the MK6, which started in 2009
    Jun 2007
    Quote Originally Posted by benough View Post
    Well Im not , I was under the impression they went CR 2008 , so if it was Pumpe Duse then why would it be so much noisier and rougher at idle.
    Apr 2008
    How many km’s did the EOS have?
    It could have been a bit more gunked up due to lower kms?
    Jun 2007
    It has 89,000 k's on it , and yes it has been sitting around a while , last serve was 86000 but time before 84000
    the last few years has been based on time not distance , so 2000km in a few years at one stage,
    Apr 2008
    OK.
    Can you give it an Italian Tuneup?
    Apr 2008
    Looks like it’s Pump Düse
    Jun 2007
    Thanks Beno , well thats sorted re dates.
    So Im presuming once again none of the Pumpe Duse came with DPF ??
    Apr 2008
    Quote Originally Posted by neil View Post
    Almost.
    For Australia, only the BMN engine, the 125kw one that was in the Passat and Golf GT Sport had a DPF
    All other Pumpe Düse engines did not have one
