Originally Posted by
lhennessy
Well I'm around the same height if not lower, on 18x8.5 et35 so a lot more aggressive and I get big rubbing on fast cornering and bumps.
JESUS!!! Thats like an extra 23mm more sticking out more than mine, no wonder you have big rubbing. How the hell can you even turn the wheels? That's almost like the equivalent of having 275mm wide tyres!! When I had mine sitting an extra 5mm lower than it is now I couldn't turn the wheels more than 45 degrees before the tyre hit the guard so I have no idea how you are running so low and with such an aggressive offset.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
