Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: DPF cleaning fluid: factory installed
  1. #21
    May 2006
    Adelaide South Australia
    Quote Originally Posted by Ryeman View Post
    Just so long as the HPFP gets sufficient lubrication.
    To satisfy that you need a fuel additive.
    Numerous Mk1 Golf diesels
  2. #22
    Feb 2014
    Central Vic
    Quote Originally Posted by jets View Post
    Which one?.
  3. #23
    Feb 2015
    If sulphur is a lubricant I'm worried if HPFP lubication is compromised by ultra low sulphur.
    From my knowledge, sulphur is engine damaging, not beneficial. Less sulphur in fuel, less soot in dpf. Maybe this helps:
    Long-term benefits projected from Ultra Low Sulfur Diesel fuel technology and diesel engine advances - Clean Diesel Fuel Alliance
    As long as you don't run the fuel tank dry or accidently fill petrol in and run it, HPFP is safe.
    Older diesel engines would benefit from additives to protect the fuel pump.
    Sent from my HTC_PN071 using Tapatalk
    MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
  4. #24
    Feb 2014
    Central Vic
    You can run the Peugeot dry as It covers how to prime using the priming button.
    I would not try it though as I'd be worried about the HPFP running dry.
  5. #25
    May 2006
    Which one?.
    This is the one I use.
    Fuel System Cleaner - CRD Fuel Enhancer | Cost Effective Maintenance
    Mixing ratio is 10ml for 80 litres. I use it in my Tiguan & Golf. It last for ages, still on my first bottle.
    One word of warning from the supplier is not to overdose.
    For my T4 TDI & Mk1 Golf diesel I use 2 stroke oil in a ratio of 1/200.
  6. #26
    Mar 2014
    Bundoora, Victoria
    My Ford has a PSA engine and only has a DPF with no AdBlue, Euro 5 compliant. I've only filled up BP diesel.
    Installed a DPF level gauge in mine so that I know when I need to liberal with the throttle to get the temp up and make a regen happen (have a temp gauge for that as well so that I know it's doing it).
    jets, have you ever had injector clicking? Did it reduce the noise of the clicking?
    Past - '95 VW Golf MK3 VR6
  7. #27
    May 2006
    Quote Originally Posted by stefcio007 View Post
    I have been using CRD Fuel Enhancer for years now so can't really say now what improvement in noise level there was. I have just come home with the Tiguan & popped the bonnet & sounds normal to me. As was mentioned on the My Turbo Diesel Forum, the CR runs more calmer than the PD engine in our Golf.
    I use 2 stroke oil as an additive in the T4,MK1 Golf & Massey Ferguson tractor & they all run quieter.
