Results 1 to 10 of 14
Thread: To Change the OIL or not
    Jul 2010
    Robina Gold Coast
    I have a 130KW Tiguan Diesel , Which i hardly drive as i have another vehicle ,
    Well its due for a service and its only done 4,000km since the last one ,as its out of warranty should i change the oil and filter or just the oil .
    Or just leave it untill i have at least 10,000km ,It seems a waste of good 507/504 fully synthetic oil ?
    Dec 2009
    Kew, VIC
    Oil (even fully synthetic) does go off with time, plus the standard filters are usually cheap paper.
    My TDI had clocked just a bit over 2000km for the last 12 months — I still changed both oil and filter, let everything else go.
    Will do a full service next time.
    Dec 2008
    Sydney/Canberra
    I'd still do it at least annually, regardless of not doing the distance.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Pacific Paradise QLD
    My Polo has only done 24000 in 7 years but has had yearly services regardless of KMs
    Gosford Central Coast NSW
    Quote Originally Posted by Idle View Post
    What evidence do you have of this claim?
    Also, with regard to the paper filter - of what significance is this? THe paper flter holds up fine cycling temperature from ambient to 100C and back again thousands of times with oil running through it - what about cold static oil will be worse than that?
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Dec 2008
    Sydney/Canberra
    I'd use an OEM paper filter over some of the better-known non-OEM garbage.
    '01 Beetle 2.0
    Jul 2010
    Robina Gold Coast
    I have been reading that Fully Synthic Oil has 3 times the shelf life of Mineral oils
    so if its just stored in the sump of a car would it deteriate faster ?
    Dec 2008
    Sydney/Canberra
    I'd still do it every year. In the sump, it is prone to moisture contamination.
    An annual service, is not just an oil change. It's an opportunity to inspect other things that are prone to deteriorate with age, such as belts, seals, rubber fluid lines for brakes and fuel, CV boots, and to also test the battery, the cooling system, and brake fluid.
    I've often found that the least-used cars, are the ones with the most problems. Perhaps consider moving it on?
    '01 Beetle 2.0
    Quote Originally Posted by ian View Post
    Probably as shelf life is usually described as being in a sealed unopened container
    Was a discussion a year or so ago and supported the above.
    Quote Originally Posted by Umai Naa!! View Post
    I like to buy cars that have been used a lot.
    A car that does 50000 in the city will have lots more wear in the clutch/DSG than one that has 200k on the highway.
    One yard around the corner had a 2007 mk5 GTI, $22k with 11000km on it. Salesman was pleased to announce it was his dads pride and joy and had only one stamp in the book....
    Not for me.
