Yikes!
What year is your R36?
The Dynaudio (Lear) amp looks like the photo on the left? (it looks new)
Is the factory amp on the right? Does it look like the one pictured below? Also, can you please post the part# if possible so I can try track down the details?
Not sure how your loom is configured, but if the number of pins are compatible, you may be able to create an adapter plug - just need to track down a wiring diagram.
If you were in Brisbane, I'd be happy to help out. Otherwise, it'll be a little while before I'm down Sydney again (at least a couple weeks or more).
