Results 1 to 10 of 15
Thread: Crankfoam
    Crankfoam
    Basically overfilled the engine oil of my 1.8t 99 A4 by nearly 500ml drove on the highway for around 60km before the music was turned down and heard the noise, the car then proceeded to the nearest highway exit at around 100km/h upon reaching the exit the car slowly died and now will spin but not fire. I have already dumped oil and replaced spark plugs still same issue first kick sounds like it goes to fire but doesnt is this now the cat converter?
    Jan 2015
    Melb
    If it had a blocked cat it would normally start up ok and then slowly die as the pressure builds up. After you turn it off you can hear the pressure escape. Are you sure the oil level was the issue? 500ml isn't much.
    I wouldn't have thought that a 500ml overfill would be enough to do damage (especially in such a short timeframe) but who knows.
    2017 Ford Fiesta ST
    Quote Originally Posted by Passat my07 View Post
    Enough to fill into the crankcase and cause the oil to foam then the car died have replaced sparks and oil
    Will the car do anything when the key is turned if any major damage has been done
    https://www.youtube.com/channel/UCAm...xsipOOyGVpVsHw
    https://www.twitch.tv/biscutmonkey
    Twitter BiscuTMonkeY
    Peregian Beach
    If the oil foamed enough to starve the bearings of oil flow you will have had a low oil pressure warning light come on the dash. If you continued to drive with no oil pressure then the engine would start knocking or rattling. I don't see how it could have affected the cat unless somehow heaps of oil was getting into the combustion chamber. If it had you would've noticed a big trail of blue smoke out the exhaust. I am no mechanic but if it now has the correct amount of the correct oil in it, then starting it and running it for a short while shouldn't do any more damage. If the bearings/big ends have run without oil then the engine will be rattly or have knocking sounds from inside the engine. If it sounds normal then it should be ok assuming you didn't drive with the oil pressure light on.
    Jan 2015
    Melb
    Were the plugs oily? What did the oil look like?
    Oil was filth dirty fish smell replaced spark plugs were doused replaced new spark plugs coped old stale oil put carb cleaner in cleared alot of stale oil up still not starting
    Jan 2015
    Melb
    Have you checked for spark, fuel and compression?
    Dec 2008
    Sydney/Canberra
    Yep, back to basics first.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Started this about a month ago finally have some
    Codes
    01262
    00544
    16487
    16507
    16515
    16711
    16716
    00515
    00670
    I know what the codes are and judging by what ive seen i need to replace? The wastage bypass regulator valve or just check? And my camshaft position sensor is gone or i need a new distributor?
