Results 21 to 30 of 32
Thread: OBD11 modifications
  1. #21
    Pacific Paradise QLD
    Quote Originally Posted by The_Slavstralian View Post
    Arrived today. I was easily able to navigate to the option. It is now disabled... according to the app. Will have to see how we go on the road at a later date
    The only thing you will notice is you can shoot up a left lane and it wont give a warning and just keep on keeping on
  2. #22
    Jun 2023
    Central Coast, NSW
    I drive the M1 often. Its infuriating how many flogs sit in the right lane on 90-100km/h With this option enabled and me in the middle lane it would slam the brakes on as I approached the person in the right lane. Dangerous if you have a truck on your a$$. I disabled it. Now it just lets me sail on past the tool in the right lane. Which is perfect. Now I can play with other things it can do.
  3. #23
    Jan 2023
    Literally why I bought this device, just came today, can't wait to try it. Did you need to have the car on?
  4. #24
    Mar 2017
    Tasmania
    Ignition needs to be on, engine does not need to be running. For some changes, you will need the bonnet open.
    Jun 2007
    Sydney, Australia
    Was given a T-Roc hire car a couple of weeks ago, only got about 1/2 an hour out of Sydney and I had to pull over to disable it. Lucky I had the OBDeleven still in my bag.
    @Doc777 I am currently in your area testing the road handling of the Audi, you have some really nice roads I've like to try the T-Roc on
    Flipper Dog
    Now - T-Roc R, Audi Q5
  6. #26
    Mar 2017
    Tasmania
    Quote Originally Posted by Flipper Dog View Post
    Mate, some of the roads down here are glorious! Just be aware - we normally have basically zero highway patrol, however at the moment there is a "blitz" going on. I believe it's mainly happening in the west and north-west.
    Jan 2024
    Drummoyne, NSW
    Does not work on Tiguan R-Line MY22
    Quote Originally Posted by Grugly View Post
    Hey @flipper - just picked up our Tiguan R and followed the instructions for the MIB 3 unit. Everything's works until getting to road side fusion where it is saying function not available.
    In OBDeleven also byte 5 has been renamed so no longer shows bits. However there was an option names Traffic sign recognition in the third row that I assumed to be the same as bit 2..
    I'll keep investigating to see if there is a way to change the bit
    Hi Grugly,
    Did you have any luck with your Tiguan R?
    I have the Tiguan all space r-line MY22 and it is the same situation regarding fusion mode.
    Overall the traffic sign recognition does not work for me and receive an error on the dash now:
    “ERROR: Dynamic road sign display”
  8. #28
    Quote Originally Posted by nova_sounds View Post
    Hi Grugly,
    Wont work in Fusion Mode as its Not applicable to AUS
    Try this method It worked in my 2019 Tig Rline
    Road Sign Settings .pdf - Google Drive
  9. #29
    Jan 2024
    Drummoyne, NSW
    Thanks Hillybilly, just tried your suggestion and still doesn’t work. May have something to do with MY22 Tiguan All space as they are made in Mexico? But when I go into the fusion menu OBD app reads “function not available”
  10. #30
    A lot depends on which model camera you have . There is a 2Q and a 3Q. One is on the older models and works the newer one doesnt. Cant remeber which is which as I dont have the Tiguan nay more
