Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Polo parts
    May 2012
    Perth, WA
    Polo parts and MORE, moving overseas sale
    Moving overseas before this financial year ends, would love to see all my stuff go to a good home before then.
    All prices are negotiable, buyer pays postage.
    -USED H&R lowering springs 45mm drop
    part# 29333-2
    $150
    -USED Set of Koni FDS dampers, passenger front has hit a kerb and I thought it's bent but turned out quiet straight. However that damper definitely needs a rebuild because the valve must be damaged and causing the steering wheel to vibrate at high speed. So price stays the same because that side needs a rebuild.
    part#2100-4041
    $200
    -USED Standard 9N3 Polo suspension set dampers and springs, normal working order before removal
    $20
    -USED Standard 9N3 Polo steering knuckle pair, removed for brake upgrade
    $20
    -USED Standard 9N3 Polo brakes front and rear, removed for brake upgrade. Include front and rear calipers, rear discs. Pads have plenty of meats left.
    $20
    -USED Standard 9N3 Polo front sway bar drop link, no noise before removal
    $5
    -USED Whiteline front sway bar drop link
    part# KLC163
    $100
    -NEW Darkside Sachs SRE Performance Clutch Kit for 5 Speed 02J/02A/02R, with sintered paddle disc
    Includes everything in the following link except the flywheel. This kit can hold 390lb/ft+ (530Nm+) of torque. Guys from darkside told me this kit fits pretty much all 1.8T 5 speed gearboxes
    darkside website
    $700
    -NEW Gearbox rebuild kit for 02J/02A/02R
    $130 , $100 if you take the above clutch kit as well
    -USED Set of 4 genuine VW PD130/150 injectors
    Fit all 4 cylinder 8 valve PD TDI engines
    They need to be calibrated before fitting to the car
    Sold as a set
    part# 038 130 073 AL
    Condition: Used, in working order
    Reason for sale: there was no one can do the calibration locally so ended up buying a fully calibrated set instead
    $350
    -USED 100 cell cat no O2 sensor hole, 3" in and 3" out. Done ~45000 km and been on the car for less than 4 years. No cloggage inside cells, only a light coat of soot
    $40
    -USED 4 Pin MAP sensor extension lead
    Made from plugs and crimps bought online, I used thicker(1.13 sqmm) wire so there won't be any resistance issue
    It comes in handy when the sensor is too far away when using the pipe kits. Been on the car for a while without any fault codes, changed to hard pipe kit so no longer need this
    Condition: Used, almost new
    $10
    06 Polo TDi
    May 2012
    Perth, WA
    More for sale
    -USED Genuine Rear light assembly for 9N3 Polo
    Condition: Used, no external damage, no leakage
    Reason for sale: replaced with the black rear light
    Only have left side now
    $60
    -NEW Non GTI version 9N3 Polo third brake light LED conversion, comes with new assembly(inc. lens and backing plate, so plug n play)
    Custom made, bright as hell, only set in Aus
    $60
    -NEW Aluminum tow hook fits most VWs
    Condition: almost new, test fit only
    Reason for sale: interfering with intercooler pipe kit
    $30
    -NEW Genuine Bosch Wiper blade for 9N3 Polo, also fit other cars see picture
    Condition: new
    Reason for sale: Bought the original wiper and forgot it will hit the CUP spoiler
    $10
    -USED Set of Rim Ringz in 17" black Rim Ringz
    Condition: Used, not scratched or scuffed in any way. Bought second handed but never got around to fit them
    Reason for sale: changed to 16" wheels
    $30
    -USED Black wheel bolt cover set of 20
    $10
    -USED Black wheel bolts Conical Seat, 40mm X 10, 45mm X 10
    $20 for a set of 10 bolts
    -NEW Aftermarket 1.9 PD TDI intake manifold gasket
    $10
    -NEW Aftermarket outer CV repair kit for AXR, ATD, BMT engines
    $15
    06 Polo TDi
    Blackburn South, Victoria
    what are the new headlights like? and got a link? thanks
    2008 MY09 Ibis White Audi S5 Manual SOLD!
    2017 MY18 Manganese Grey VW Passat Alltrack Wolfsburg SOLD!
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    May 2012
    Perth, WA
    Quote Originally Posted by FarQ View Post
    You'll most likely to find them on google with key word "9n3 polo led headlight'
    They look like this
    06 Polo TDi
    Jul 2015
    VIC
    Are the tailights genuine vw??
    Sent from my SM-N920I using Tapatalk
    May 2012
    Perth, WA
    Quote Originally Posted by PULS8T View Post
    Yes they are
    06 Polo TDi
    May 2012
    Perth, WA
    Seat style intercooler pipe kit
    After replacing my pipe kit with the Darkside hard pipework, I realised I have enough pipes to make up nearly 2 pipe kits
    06 Polo TDi
    Nov 2012
    WA
    I will take the mirrors
    08 9n3 Polo GTI
    Mods: heaps
    May 2012
    Perth, WA
    Quote Originally Posted by rgvlee View Post
    Thought you fixed your mirrors already?
    06 Polo TDi
    Nov 2012
    WA
    Nah the passenger mirror fell off.
    I managed to catch and fix the drivers mirror. But may as well grab both off you can't hurt.
    08 9n3 Polo GTI
    Mods: heaps
