do you have a link to where I can buy the genuine Australian vw tow bar?I'm with IsDon, sounds like poor design to me. Tiguan R-line here...I spent 12 months trying to decide whether to grab the OEM or the Genuine Australian VW towbar which is made by Best Bars, ended up going with the Gen VW bar so was sourced via a colleague at trade price which was around $1150 and ended up fitting it myself which took around 4 hours. There are two components, the towbar kit and the electrical installation kit, both with full instructions. The electrical installation also includes the module and all you have to do is plug in 2 connectors behind the LHS rear trim, connect one 2-pin block under the dash and all done...it's actually quite easy + nothing like the tow bar installation on the Mark 1 tigs. The only issue you will have, with the electrical installation kit there are 3 codes that need to be individually programmed into the vehicle and even though I have the VCDS cable (not the latest version) my chances of being successful would be fairly remote as there are so many areas that need to be programmed to make my Tig 'trailer aware' so I just rang up the dealer that I purchased the car from, took it down and they did it for me, wait for this...for free!
As an FYI, I leave the tongue/ball on and have no issues when reversing. Hope that helps someone
