View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
92. You may not vote on this poll
  • Traffic Sign Recognition
    24 26.09%
  • Speed Limit on the Navigation System
    7 7.61%
  • A combination of the two, which VAG doesn't allow in Australia.
    61 66.30%
Page 26 of 30 FirstFirst ... 162425262728 ... LastLast
Results 251 to 260 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #251
    Quote Originally Posted by Blackpaladin67 View Post
    Hi did you mean that you have a workaround for the 3 seconds timeframe when stopped from TJA ? If so please share.
    Unfortenately, I ment that you can get my scans and compare with car w/o TJA to activate it - if possible in car w/o TJA.
  2. #252
    Aug 2017
    Uk
    Quote Originally Posted by bestyjny View Post
    deemed not to be a tweak for vcds/obdeleven, can be done with vcp but chargeable
  3. #253
    Dec 2017
    QLD Australia
    Quote Originally Posted by Jap View Post
    Vcp being a dealership type tool?
    Sent from my SM-G935F using Tapatalk
  4. #254
    It requires uploading a parameter set to the A5 camera module.
    This can only be done with either ODIS (dealer tool, but they won't do it for you) or VagCanPro which is an aftermarket tool not unlike vcds but with some additional functionality.
  5. #255
    Dec 2017
    QLD Australia
    Ta sounds like a bit dangerous insurance decline, territory might just stick to pressing the resume button
  6. #256
    Aug 2017
    Uk
    it still won’t get rid of the 3 second limit, we’re talking enabling TJA on a car without it
  7. #257
    Dec 2017
    QLD Australia
    New project
    Has anyone enabled the graphics for engine coolant and oil on their mib ?
  8. #258
    Aug 2017
    Uk
    already enabled in mine
    as I understand it’s a SWaP feature (dealer only activated (IF you can find a dealer that will/can do it))
    but under module 5A, adaptions, car function adaptions gen 2, there is a menu_display_SportHMI, you could try setting that to activated (and also over_threshold_high of course)
  9. #259
    Mar 2018
    Hi I have a Passat Alltrack 2017. It has the Luxury package which includes the led headlamps and drls. This also has dynamic cornering lights. Is it possible to enable light assist which is what I assume the feature to automate the high beams with the coding that NZ_GolfR provided. I am quite confused what the difference between light assist, dynamic light assist and high beam assist? Are they the same thing?
    I am also looking to see if I can enable Adaptive Lane Guidance. Would this be the same coding as the Tiguan? I have the basic lane assist but I want the ALG until someone works out TJA.
  10. #260
    Aug 2017
    Uk
    I think high beam assist puts the high beam on when it doesn’t sense a incoming car or a car in front, whereas dynamic the high beams are on all the time but it has shutters in the headlights and if it senses a car in front it will dip straight ahead (but the sides will still be on high) and if a car is coming the other way it will dip both lights on the right side and both lights on the left side will stay on high beam
    TJA has been worked out dude, it’s a VCP tweak and chargeable
