View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
92. You may not vote on this poll
  • Traffic Sign Recognition
    24 26.09%
  • Speed Limit on the Navigation System
    7 7.61%
  • A combination of the two, which VAG doesn't allow in Australia.
    61 66.30%
Page 10 of 30 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #91
    Apr 2017
    sydney
    Hi,
    There didn't seem to be clear instructions on this thread on how to enable the Adaptive Lane Guidance. Instructions below are for OBDEleven owners:
    1) Go to Front Sensors Driver Assistance System in the Control Units (Module A5)
    2) Security Access - code is 20103
    3) Coding - Point of intervention - Set this to early (setting via menu)
    You should then see the option in the driver assistance settings of the car menu. Works perfectly for me by keeping the car centre in the lane. But this only works above 65km/h. So there are two more changes missing to make this into a TJA function:
    1) Allow Adaptive Lane Guidance to work below 65km/h
    2) Allow the ACC to stop and start without the 3 second limit
    Hope this helps!
  2. #92
    Nov 2013
    AUS
    Cheers mate, OP updated.
    Edit: I meant the OP in the Mk2 Tiguan VCDS Tweaks page was updated.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  3. #93
    Sep 2016
    SE Melb, Victoria
    Do you know how to get the additional Warning Level option to appear like peanut did in his post #1 in this thread?
    A guide to enable EU specific features for AU Spec Tiguans-img_20170316_151121-jpg
    Pure White MY17 Tiguan 162TSi R-Line DAP Pano
    Blue Golf MkV TDi Pacific
  4. #94
    Apr 2017
    sydney
    Quote Originally Posted by VWVY View Post
    Hi,
    no I haven't managed to enable the warning setting but I don't think the warning is relevant. If you have the DAP package then lane assist is actively steering for you rather than the basic lane assist which gives you a warning only. So if you have Adaptive Lane Guidance which is the most advanced lane assist option, I'm not sure why the warning would be needed or even useful.
  5. #95
    Sep 2016
    SE Melb, Victoria
    would not know what it does to the lane guidance behaviour if we can't bring that option up to try ... otherwise anybody that has that option can tell us its function
  6. #96
    Feb 2017
    Melbourne, VIC
    Thanks for posting the ALG activation instructions.
    Is there any other step that needs to be done?
    OBDeleven first timer here. I followed your instructions but the menu on my imfotainment system doesn't show ALG, even after turning the ignition off and on again.
  7. #97
    Apr 2017
    sydney
    Quote Originally Posted by latearrival View Post
    Thanks for posting this!
    Is there any other step that needs to be done that needs to be done?
    ODBeleven first timer here. I followed your instructions but the menu on my imfotainment system doesn't show ALG, even after turning the ignition off and on again.
    No that was it. Make sure you press the green ticks to accept changes. Maybe try the adaptions section and change the point of intervention to early. But I didn't have to do this
  8. #98
    Feb 2017
    Melbourne, VIC
    I did press the green tick & got the coding accepted message. Would you mind telling me more about the Adaptions setting?
  9. #99
    Oct 2016
    SYDNEY
    laterarrival. after playing around with these ODB, please show it clearly ....
  10. #100
    Feb 2017
    Melbourne, VIC
    Sorry guys. User error! In my haste I had chosen "early", not realising that the option was "early (setting via menu)". Now off to test it on the freeway...
    EDIT: Just took the Tig for a spin down the freeway and ALG works as advertised - the car stays between the lines rather than zig zagging between them (or hugging one). Given the constant requests to return your hands to the wheel though, I do wonder what use ALG is, apart from the sheer novelty value.
