Page 11 of 24 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 236
Thread: VCDS Tweaks
  1. #101
    Oct 2017
    Copenhagen, Denmark
    Quote Originally Posted by Jap View Post
    eleven dude
    Thanks, man! Brilliant!! Cheers!
  2. #102
    Oct 2015
    Istanbul
    Quote Originally Posted by vwcaddy123 View Post
    Thanks for your answer - but are you using OBDEleven or VCDS?
    On some page I found the below instruction to change the look of AID to be like Arteon 320 km/h look, but I do not see any channel named like that when I enter adaptation in instruments at my 2017 Passat B8 ? I am using VCDS. Thanks.
    Select Control unit 17-Instruments
    Adaptation - 10
    Channel: ENG153766-Tube_version
    Change stored value: "variant_0" to new value: "variant_4"
  3. #103
    Aug 2017
    Uk
    Oh, to get the dots on the AID is not under tube version,
    for the dots its
    Module 17 dash board
    Adaptation
    Display depiction
    Default is 1
    Change to 3
    BUT it also changes the colour of the lines to gold/orange and the lines on the MIB stay the default colour unless you have colour change in the settings of the MIB under background lighting, or you have enabled it
    all done with OBDeleven as I don’t have vcds
  4. #104
    Oct 2015
    Istanbul
    Hi. If this was for me, I am not asking about the dots. I am asking about showing the speedometer top speed as 320.
    for the dots its
    Adaptation
    Display depiction
    Default is 1
    Change to 3
  5. #105
    Aug 2017
    Uk
    You’ll have to change the tube version to 3 (I think) to get the R clocks
  6. #106
    Quote Originally Posted by mythik View Post
    So. Spent a bit of time last night making High Beam Assist work on a 2016 VW Passat Alltrack.
    Step 4. Open Coding menu and look at the Current coding. Copy that fully and paste it into the New Coding window below. You need to change the coding from 1C to 1D as shown in the final version in the picture so you can see where 1D is and where yours will show 1C
    Attachment 30499
    mythik: It might be interesting to understand why your observational instructions have worked - I hope the following explains this!
    If you look closer at your picture of the VCDS screen above, you will notice that your highlighted piece of the code-string for the BCM is the 5th & 6th digit from the LHS. This means that you have highlighted Byte 2 (remembering that the extreme left-hand-side pair of digits in your picture is Byte 0).
    So, according to your instructions, your original Byte 2 value was hex1C, which has the equivalent binary value 0001 1100. And, you have changed the value of this byte to hex1D, which has the equivalent binary value 0001 1101. This means that you have altered Bits 0 and Bit 1 in Byte 2 (remember that in binary, the extreme RHS digit is Bit 0 and the extreme LHS digit is Bit 7)
    Specifically, the change that you have made to Byte 2 is this:
    • Original Bits 0-1 = hex0
    • New Bits 0-1 = hex1
    The Long coding Helper screen for Bits 0, Bit 1 on Byte 2 looks like this:
    Translating the options into English yields this:
    • hex0 =Halogen
    • hex1=Halogen_main_beam_assist
    • hex2=Xenon_AFS
    • hex3=Xenon_AFS_and_main_beam_assist
    • hex4=Bi-xenon_AFS
    • hex5=Bi-xenon_AFS_and_main_beam_assist
    • hex6=Bi-xenon_AFS_and_MDF_GLW
    AFS
    , (Advanced Frontlighting System)-dynamic cornering light (via the cornering light CAN bus)
    FLA (Main beam assist) Assistance system which supports the driver when changing from main beam to low beam headlights, in order to prevent dazzling other road users
    hence -why your tweak works!!
  7. #107
    Oct 2015
    Istanbul
    That's the problem. With OBDeleven I guess you have this "tube version" option, but if you are using VCDS like me and a few others there is no "tube version" under adaptation. We only see "display depiction" which does not help to get the R clocks.
  8. #108
    Aug 2017
    Uk
    As I’ve said dude, I’ve not got vcds, so really can’t help you on that, sorry
  9. #109
    ^^hmm............ VCP can find the adaptation channel!!
    and so can OBD11
    So why can't VCDS?
    Does anyone who has found this illusive adaptation channel using a a non VDCS device , also have a VCDS device? If so, can they make an admap of the module @ address Hex17 and post it up here?
  10. #110
    Aug 2017
    Uk
    Would it be in German?
    Röhrenversion
