Page 3 of 26 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 252
Thread: Dynamic Light Assist
  1. #21
    Sep 2017
    If masking means the big gap of light in the middle when the lights sweep out, then no.
    They definitely dip beam when approaching oncoming traffic though.
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
  2. #22
    Feb 2013
    Perth, WA
    But can you see the masking in the middle?
    My 2009 car with AFS does the sweeps.
    But it cannot mask like that.
    I can't code the CE module in VCDS, it's all done through adaptations.
    Also, I can't see bit 6 on Byte 4 on the 55 - (headlight range) module either.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
  3. #23
    Quote Originally Posted by DR074 View Post
    That's HBA high beam assist.
    Not DLA.
    You need the parameter set applied to your headlight range module.
  4. #24
    Feb 2013
    Perth, WA
    That sounds like you've enabled HBA to me.
  5. #25
    Quote Originally Posted by Wynnston View Post
    You will need to just manually change the bit.
    Counting from right to left where the right hand side is bit 0 (if using vcds)
  6. #26
    Sep 2017
    Ok, cool. That's what I was after.
  7. #27
    Sorry bit of confusion with similar terms..
    By masking I mean the dark spot which is being created on the centre of the beam pattern on startup.
    The BCM has no coding, it's all masked as zeros.
    All behaviour is controlled through adaptation channels.
  8. #28
    Feb 2013
    Perth, WA
    Ok, yeah, looks like we can only get HBA to work without Kamold's parameters, and even then, we might not have the right headlights.
    Kamold, I'll try and get under my bonnet tomorrow and note down the part codes of the physical headlight. It may help you work out which ones are high and which ones are not.
  9. #29
    Sep 2017
    Just checked, definitely no light gap.
    Sorry boys for the run around, just trying help. I've got so much cool stuff out of these forums. Thought I better try give back.
  10. #30
    This is all brand new to me as I don't have a new Passat.
    So your assistance has helped clarify the situation further
    Thus far it looks like the Aus delivered LED Passats are all category 3 requiring parameter upload to complete the puzzle (if you count 2 from 2 as anything like a significant sample size lol).
