Results 1 to 10 of 10
Thread: Windshield sprayers not working
    Jun 2015
    Willy, Victoria
    Hi guys
    As the title says my front windshield washers have stopped spraying. The passenger side headlight washer still sprays but the drivers side doesn't. It doesn't even fully extend.
    Any ideas? Could it be a blockage somewhere? Pump not generating enough pressure?
    Thanks
    Sent from my SM-G955F using Tapatalk
    Albany, WA
    Use a stitching needle/paper pin to clean the tip. Also it depends on the wiper fluid you are using, sometimes if its too concentrated it can gunk up if not used regularly and too much sun . A very good sign is that the passenger side it working meaning most of the other issues less likely. Mine had slightly lower spray pattern and I did the above, used quite a bit of spray fluid at once and eventually the gunk came out and its working fine now.
    Jun 2015
    Willy, Victoria
    Hey so I tried cleaning them out and that made no difference. I actually took the sprayers off and even still no spraying. In fact none of the sprayers are working now. Not even the headlights. The pump is definitely running but not creating any flow. I also checked vcds for faults of which there are none. And yes the water bottle is full. Topped it up.
    Dec 2008
    Sydney/Canberra
    Pump inlet could be blocked with algae.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2005
    I don't the windscreen washers are a reportable system to canbus
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jun 2015
    Willy, Victoria
    Quote Originally Posted by Umai Naa!! View Post
    Oh joy. It's not the easiest part to get to...
    Jun 2015
    Willy, Victoria
    Quote Originally Posted by aprr32 View Post
    Ok. There are some electrical plugs connected to the sprayers inside the skin of the bonnet. Are they solenoid operated?
    Dec 2008
    Sydney/Canberra
    They're just the water hoses.
    If you remove the lower inner guard liner on the right hand side, you'll see the bottom half of the washer bottle where the pumps are.
    Pull the pumps out and make sure they're not blocked with crap.
    '01 Beetle 2.0
    Jun 2015
    Willy, Victoria
    So I got this fixed now. As it turns out the pumps and the bottle were fine. No algae or anything like that. There was a blockage somewhere in the hose between the pump and the sprayers. I ended up having to run in an entirely new hose as tge original is buried in a split corrugated hose with other wiring.
    Albany, WA
    Great.
