Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 115
Thread: Snerlo's R36 DRL Mk2 Installation
    which circuit did you guys get your 12v power from?
    My chinglish instructions have it going to the cigarette lighter on the interior fuse box.
    Looks like the engine bay fuse box could be a better option.
    Nov 2010
    Gotta go internal mate. I dont think that any of the fuses are switched in the engine bay. I went and piggy backed a fuse at the drivers side end of the dash. You can buy piggy back fuses from jaycar. Easiest way to do it. You come through a hole where the clutch would be in a manual car.
    Cool thanks.
    Tested the dimming, it actually works fine.
    Jul 2013
    Hills District
    I have these DRL and I know exactly how they work.
    Did you notice that every time you turn the ignition on the parker LEDs will blink a couple of times?(My MY10 does and oversea MY09 onwards does)
    And these DRL turn on when the ignition is on, so when the parker blinks, the DRL will dim a few times as the parker blinks.
    That's the bcm testing the circuits. It's expecting filament globes so pulses the globe to test continuity with low voltage. It's enough to turn on an led. You should see the tails on my octy at startup, its like a disco!
    Jul 2013
    Hills District
    thats right. so if you connect the DRL's dim wire to parker, expecting the DRL will dim a few times.
    Nov 2014
    New Zealand
    Hey Snerlo. Looks good!
    Could you post a link to the site - definitely interested in these.
    Nov 2010
    Look the goods. That is one of the things on my to do list!
    2008 Passat Wagon - 125 TDI - Black on Black - All stock, for now!
    I took a shthouse video of them in operation.
    Its on the facetube:
