Results 1 to 10 of 12
Thread: Passat R36 Diff lock up
    Jan 2011
    Hi all
    Need help. My R36 has had its diff locked up.
    When putting it reverse it moves a little and then gets locked up (metal on metal sound) and the front wheels get locked up.
    Putting it in neutral is the same. Unable to push it
    Putting it in drive is ok and moves forward.
    Anyone experienced these problems?
    I have had the clutch and bearings fixed on the gearbox 3 months ago.
    Sent from my SM-G935F using Tapatalk
    Dec 2008
    Sydney/Canberra
    Check the oil level in the Haldex and diff.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2014
    Melbourne, Vic
    How did you go? This is a interesting one.
    Have you put it on a hoist or jack stands to get all 4 wheels off the ground and see if it's the front or rear locking up? That might narrow down the point of failure to the Dsg or haldex
    Jan 2011
    Its definitely the front wheels, back wheels are not locking up. Had to be dragged on the tow truck.
    Took it to VW (dont know why) just said its gearbox.
    Taking it to a gearbox specialist (done my clutch there) this week see what they say.
    See how we go
    Dec 2008
    Sydney/Canberra
    Yeah that's interesting.
    Never heard of this issue before.
    '01 Beetle 2.0
    Mar 2014
    Melbourne, Vic
    Possibly a seized bearing in the Dsg by the sounds of it. Hopefully not too expensive!
    Apr 2017
    Stanhope gardens
    That sounded rad until I read the metallic bit.. I hear the auto hold at the back tho, I'd make sure that doesn't play a part in the front? I'm no mechanic but would pulling fuses help diagnose??
    Sent from my ZTE Blade L5 using Tapatalk
    Jan 2011
    Seems like its the transfer case...
    Find out once it comes off
    Dec 2008
    Sydney/Canberra
    Unsual for the bevel box to die.
    Although, if it's run out of oil it's very possible.
    '01 Beetle 2.0
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Wasserboxer View Post
    Autohold is part of the ABS.
    '01 Beetle 2.0
