What coding are you trying to apply? Just try putting in the most basic string you can (whatever is closest to 00000000 or whatever) and apply. Then try and change to your correct settings.
Hi all I'm having trouble with my park assist install ,I have wired everything up and up to the coding stage .I have 1t0 919 475 m module and vcds can read it but cant do a single code it says -this appears to be an uninitialized control module click yes no or cancel (yes is use default values of 12345 123 12345) I click yes and I get -coding rejected error 31 ?? Has anybody successfully installed pla 1.5 ?
Sent from my SM-G935F using Tapatalk
Just trying to code new module for ops,rvc,automatic transmission stuff like that but wont accept a single code .strange that it can communicate with the module and when I swap over back to standard ops module it can code to what ever on default values.also the new park assist button works and shows in the cluster screen so I was thinking maybe my abs module is too old and doesn't support pla 1.5??
kit like this one
Ive got park assist in my car and have used it once in 5 years.
I found it wasnt as accurate as it was supposed to be and find it quicker to use my mirrors and rear view camera.
Even the lines on the reversing camera arent as accurate as they should be. If I backed up till the red line was on a cars bumper behind me I would have hit it.
Eyes and mirrors for me Im afraid.
I'm hearing you but I still like the challenge and I think it's a cool feature even if I don't use it ,anyway I'm kind of committed my car is in bits at the moment
Can you post a full autoscan?
Might need to upgrade to a b7 abs like you have to for acc
maybe I need a older PLA module like the 1t0 919 475 G or H first of the PLA 1.5 ? OR even the 1t0 919 475 B which is PLA 1.0 out of 08 passats? mine was just the original 8 sensor with no ops or park assist. anyway here are my faults.
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 3C0 907 115 T HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404004319070160
Shop #: WSC 00028 028 00001
VCID: 3169F346A88957962BD-8064
1 Fault Found:
008577 - Performance Malfunction in Cooling System
P2181 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 126675 km
Time Indication: 0
Date: 2001.14.12
Time: 10:24:47
Freeze Frame:
RPM: 1770 /min
Load: 39.6 %
Speed: 89.0 km/h
Temperature: 63.0°C
Temperature: 27.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776413240
Coding: 0003414
VCID: 1F4D05FECE1DD1E68D9-804A
No fault code found.
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00003001
Coding: 0000000002
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 800FE6821BA38E1E143-80D5
1 Fault Found:
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 16
Reset counter: 97
Mileage: 135209 km
Date: 2009.14.02
Time: 16:53:31
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005275691
Coding: E4848A0700041A00470F00000F000000000958415C00010000 0000000000
VCID: 71E93346680917966BD-8024
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 201007 022 0601
Coding: 00046997
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 301007 046 0204
Coding: 00208933
Shop #: WSC 00028
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 M HW: 1T0 919 475
Component: PARKHILFE PLA H07 0113
Revision: -------- Serial number: 50631124805910
Coding: 000000
Shop #: WSC 00000 000 00000
VCID: 4581B796CC01EB36E75-8010
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 135209 km
Time Indication: 0
Date: 2009.14.02
Time: 16:53:30
Freeze Frame:
Temperature: 37.0°C
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
Component: J0527 0030
Revision: 00035000 Serial number: 3C0953507
Coding: 0001411
VCID: 72EB3C4A6D0F2C8E927-8027
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments (J285) Labels: None
Part No SW: 35D 920 880 A HW: 35D 920 880 A
Component: KOMBI H01 0505
Serial number: 00000000000000
Coding: 140B01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 285F1E225353165EFC3-807D
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 N HW: 3C0 907 951
Component: J533 Gateway H14 0172
Revision: H14 Serial number: 1091G1112300F0
Coding: FDA07F06400602001003
VCID: 2C57E2328FAB3A7E18B-8079
1 Fault Found:
02830 - CAN-Extended Separator for Driver Assistance Systems
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 15
Reset counter: 97
Mileage: 135209 km
Time Indication: 0
Date: 2009.14.02
Time: 16:53:31
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3979CB6670F99FD693D-806C
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 A
Component: RNS-MID H04 3810
Revision: AB001001 Serial number: VWZ6Z7G5261003
Coding: 00000442040000900000
VCID: 2F6DF53E7EBD41663D9-807A
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1132
Revision: 32008001 Serial number: 00000529679001
Coding: 0000757
VCID: 3B75D16E7AC5ADC6811-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 3663C05A41E770AE7EF-8063
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Mileage: 135200 km
Temperature: 43.0°C
Voltage: 12.90 V
Voltage: 12.70 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 18910A0001860E7600001C1FE0085F0A007800
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1132
Revision: 32008001 Serial number: 00000061379001
Coding: 0000756
VCID: 3C77D2727FCBAAFE88B-8069
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000220940
Coding: 0000057
VCID: 29591B2680592F56E3D-807C
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Maybe you need the passat version. 1T0 might not work.. try a 3AA like 3AA 919 475 L which is what i have with park assist on a 2013 b7 passat.
