Results 1 to 10 of 10
Thread: Foggy headlights
    Sunshine coast
    Foggy headlights
    My MY2013 Passat headlights has started to 'fog up'. It seem that unlike my old Golf 5 that was all foggy on the surface, it seems to happen inside the glass. Does anyone know if there's a way to fix these? The golf headlights could be fixed by (a lot of) polishing.Foggy headlights-img_20170604_180411-jpg
    132TSI Tiguan Allspace
    Jan 2018
    Griffith NSW
    Wondering if you ever found a fix as I have the same issue and mine appears like it is on the inside of the lens as well.
    Mar 2015
    Same here in my B7. I also see the fog inside after hand washing the car.
    Sunshine coast
    No solution yet. It's definitely not moisture though.
    Jan 2018
    Griffith NSW
    Mine is not moisture either. Almost looks etched or like tight swirls from an orbital sander.
    Jul 2013
    Hills District
    I guess it's plastic aging, from the sun and the heat from the light bulb.
    It's IN the plastic, wont come off by sanding/polishing.
    Sunshine coast
    Ok, I think that should be covered by statutory warranty then? a five year old car with foggy headlights?
    Jan 2018
    Griffith NSW
    I agree, but following some experiences I have had with VW recently over some other issues I am doubtful they would do anything to assist with this.
    Dec 2015
    Newcastle NSW
    Yeah my MY11 passat has this, its weird as during the day the lenses look clear but headlights on you can see fine chip like defects
    Jan 2018
    Gippsland
    Yep my 2012 passat has this too, if anyone has any luck with vw fixing it let us know.
