There is a breather hole in the middle of the plug.
Unless there are any fault codes or problematic behaviours, just clean it off.
Was the DSG overfilled at last service?
If the proper level procedure isn't used it's easy to over fill.
Hi. How common is mechatronic connector/plug to leak fluid out of the pins/harness? Is this a bad sign? Can it be repaired?
Any update?
