Results 1 to 8 of 8
Thread: Parking Brake Error
    Jul 2014
    Parking Brake Error
    About 3 (yes, 3) parking brake switches later I am still finding myself having to replace it. The original which was revision A (3C0927225A) kept flashing a parking brake fault on the MFD. I replaced it with a C revision which worked for a while then that went faulty. I replaced it with another C version and perfect! Until yesterday. The parking brake still functions correctly at the moment, but eventually it'll turn into the switch not working at all. The lights in the unit are the first to go faulty, then it'll throw an error.
    What am I doing wrong?! Surely they aren't considered a consumable?!
    Quote Originally Posted by seanmau5 View Post
    Well.....it IS a Volkswagen so perhaps it is.
    2017 Ford Fiesta ST
    What is the fault in vcds? I had to replace the epb controller as it had CPU faults.
    Jul 2014
    I haven't been able to scan as I don't have a VAGCOM cable. I read about the controller a little earlier. Thought my situation may have differed from what I read but maybe not. Stupid car.
    From what I understand the switch fixes most common faults with these however the controllers can also be problematic (as it was in my case).
    Since I replaced mine it's been perfect, at least 12months now I think.
    Jul 2014
    How 'genuine' and 'OEM' are those $15 switches on eBay and AliExpress? Could the problem be that they aren't actually that genuine.. Hmmm
    Pacific Paradise QLD
    Genuine fakes probably
    A switch is a switch.
    One manufacturered to a higher standard will last longer.
    But if the fault is recurring then it may be epb module rather than the switch (es)
