Sounds like leaf litter in the blower fan.
When was the cabin filter last replaced?
So this car is starting to wear very thin on me..
Got in the car this afternoon, started it, air conditioning powers up and makes a noise as if something is striking the fan. Noise increases and decreases based on the speed setting. AC on/off doesn't have an affect.
https://youtu.be/fUGPH80plMY
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Major service last Thursday. I'll check the job sheet but I'm sure that is something that would've been done.
I suppose that makes sense though. All this rain, moisture in the air, probably why the air smells damp when the AC is off.
The car is going back tomorrow for castor bush replacement, they can check it out.
Stuffed blower motor.. $650 supply and install..
Think I'll do the work myself thanks.
They're not too hard to do. Probably 30 minutes tops.
Glovebox out, and the blower motor is basically the bottom section of the HVAC unit.
'01 Beetle 2.0
I think it's also possible to do without removing the glovebox. We shall find out tomorrow
EDIT - scratch that.. Found the little locking tab
Thanks Becke......
Took the opportunity to have a look at it myself this afternoon. **** of a job removing the glovebox, a lot of jiggling and swearing. Anyway, managed to remove the blower motor and this was inside. I'd say Sydney's hot weather over the last couple of months affected the adhesive and it's fallen in from up higher.
Saved yourself $650 - that's a result!
Good stuff
