Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 4 motion front to rear ratio
    Nov 2009
    It's a theoretical discussion of which I cannot claim any full understanding, let alone authority
    Here is a more detailed explanation of the 'front wheels on ice' scenario
    For the purposes of this discussion, the statement is wrong, and suggesting that a Haldex can (by design) send 100% torque to the rears is misleading. Let's not spread misinformation on the Internet - there's enough of that already.
    That theoretical is discussing the nature of torque transfer and mechanical differentials, and their disposition to send more torque (in some cases 100%) to the output shaft with the least load. However, it's not about the ability of a Haldex AWD system to apportion torque across specific axles. If we want to apply the same semantics, a Haldex-equipped vehicle is 'mostly' 1-wheel drive (one of the two front wheels), and at other times usually 2WD (one front, one rear depending on the wheel on each axle with the greatest load).
    Torque is a tricky thing to measure (just look at the huge complexities and variations involved when measuring it on a dyno), but when discussing any real-world operating condition - when all four wheels are touching the ground - a Haldex-equipped vehicle is essentially FWD, and at most sends 50% of engine torque to the rear axle (which means usually one wheel on that axle).
    May 2016
    Gold Coast
    Thanks everyone for contributing to this thread.
    So it was a wet day today so on the way home from work I tried a hard(ish) launch from standstill and to my dismay was greeted with buckets of front wheel spin and axle tramp. Houston we have a problem! I did notice when I was doing this that the little 'traction control' light flicked on.
    So I guess I am off to the VW specialist...
    Sent from my E6653 using Tapatalk
    Quote Originally Posted by AdamD View Post
    Thanks for the clarification Adam, makes more sense to me now
    dvkent please report back to the thread on the outcome as it's always good for anyone else who may have a similar issue to know what happens. Nothing worse than finding a thread which sounds like your issue only to have the poster disappear without reporting the resolution...
    Nov 2009
    Have a read of this thread dvkent:
    Uh Oh, v6 passat without awd = balls
    I wouldn't be surprised if this is the issue you're experiencing too.
    May 2016
    Gold Coast
    Will do. I am taking it in on Tuesday for someone to check.
    May 2016
    Gold Coast
    Had the CC looked at today and the diagnosis is (as suspected) the clutch pump in the Haldex. So the bank account will be $1100 lighter in the coming weeks.
    Dec 2014
    Alternatively have a read of VW's comprehensive Self-Study Programme number 206 at the link below. It's 44 pages of explanations on Haldex mechanicals, hydraulics and electrics.
    http://www.volkspage.net/technik/ssp/ssp/SSP_206.pdf
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
