Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 141
Thread: VAG-COM scanning, who can help
  1. #91
    bennjamin is offline Volkswagen Fan
    Mar 2012
    Sydney NSW
    What's your issue?
    flat spot / fuel cut under WOT at higher RPMS - want to see if any codes correspond to bad fuel pump or issue with (known) camshaft issue
  2. #92
    h100vw's Avatar
    h100vw is offline Sponsor VWwA Super Moderator
    Brisbane, Queensland
    Quote Originally Posted by bennjamin View Post
    MK4 GTI, you can't see the AFR/lambda with VCDS, so that's no help to you. You need an external wideband probe to see it.
    What's your known camshaft issue?
    Is the car chipped or standard?
    My advice, based on the snippets of information. Fuel filter, cheap/quick/easy to fit. A new set of sparkplugs, I have fixed a misfire/hesitation with plugs before. This is not the best way to diagnose the problem really.
  3. #93
    Jmac's Avatar
    Jmac is offline Factaraidh Teignoelaiche
    Aug 2007
    Brisbane.
    Known camshaft issue on an AGU?? keen to hear about that one. Fuel cut ?? under WOT, You have a Gti Mk4, im sure itll be boost cut, Check your vac line to your wastegate. Common to turn to sticky goo and stick together and stop the wastegate opening properly, this will over boost and cut the thing big time, seen it lots on the Mk4, been with VW before the internet came about ( sorry had to drop my new line for the google mechanics and in no way aimed at you my friend, just wanted to christen it) but havent seen any cam issus.
    Good luck
    Jmac
    Technician before the internet came about
    Audi/VW/Porsche Factory trained tech 24+ yrs exp
  4. #94
    Mar 2012
    Sydney NSW
    Sorry guys it's a 2006 Mkv gti -
    There are "known" issues with the spec A camshaft in the earlier Mkv gti's - mine is one and I have experienced something similar to the symptoms so hence the worry :0)
    Just to update I have changed the fuel filter - spark plugs are about 35,000ks old and do need a change. But the car pulls hard 1st / 2nd gear and falls flat at WOT
    A scan should help isolate the issue/s
    Thanks again , I won't expand upon this as its hijacking this thread !
  5. #95
    h100vw's Avatar
    Now we are talking about the right vehicle... You should log measuring blocks 2 31 99 for fuelling, 3 20 22 for ignition, 3 115 118 for boost, 115 112 and 118 for EGTs and 32 111 at idle to check for intake leaks.
    Run the car from 1500 revs in 3rd to the redline if you can.
    After a scan I think you'll be much wiser. I am in Sydney next week and might be able to help you, but I have a few others to tune first.
  6. #96
    Mar 2012
    Sydney NSW
    you were right - a fair chunk wiser and happier !
    Now , next challenge is to work out why the map cant be read
  7. #97
    h100vw's Avatar
    Did you see my email, we have that covered now.
    I am pretty sure it's had something else loaded previously. I tell you what, you should try the cruise control and see if it suddenly gets a load of power... Just in case it has APR in there and no one said anything.
  8. #98
    k0e1 is offline Dubber
    Aug 2012
    sydney, NSW
    Hi everyone, just got a MY12.5 polo gti and want to get 2 codes done. Anyone in sydney free to help out ?
    1. turning off warning on the bluetooth unit when it is unplugged (touch adapter)
    2. activating auto lock and unlock
  9. #99
    alik is offline Dubber
    Apr 2012
    NT
    I will have a VCDS HEX-USB-CAN cable in a week or so. Happy to lend it out to anyone in Darwin anytime.
  10. #100
    Kevlarman is offline Dubber
    Sep 2012
    I've got a Micro-CAN cable in the Hurstville area, so can help out relatively recent Golf owners.
