Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 92
Thread: MkVII Brakes (Pads, Rotors and Calipers) - Discussion and Questions
  1. #31
    Quote Originally Posted by agentthumb View Post
    If you have a C clamp big enough, you can make it work
    It's probably as you said, the rotors were probably worn equally until one of the pad wore out first. Once it's metal on metal, it doesn't take long!
    Sorry mate, one more thing, will i really need a syringe to suck out some fluid or will it be okay just to push the piston back? Sorry if its a dumb question as this is the first time doing it myself
  2. #32
    Mar 2015
    Warner, QLD
    Quote Originally Posted by Golf7Tdi View Post
    No such thing as a stupid question. Only stupid assumptions
    You don't have to have it. Depends on what your mechanic has done between services. When the cars roll off the factory floor, the brake fluid is filled to the full line with new brake pads.
    As the pads wear over time, the pistons in the calliper moves further and further out to keep the pads in contact with the rotors. This leads to the fluids in the reservoir dropping below the "Max" line but should still be well above the "Min" line. Some mechanics leave it as is (which is what you are supposed to do), other's top it up.
    Topping it up creates a problem when you replace the pads. As the new pads will be thicker than your worn pads, you have to push the pistons back to their outer position to accept new pads. This forces brake fluid back up the line into the reservoir, which if topped up, will overfill. And it will leak everywhere (trust me, I learned the hard way )
    Best to have a syringe or something ready to remove the excess fluid when you are pushing on the pistons.
    Also, check to see if your brake fluid is currently near the "Max" line as an indication to see if your mechanic has topped up the fluid.
    If you decide to remove fluid, only remove what you need to. The last thing you want is for the level dropping below "Min" line, and air getting into the system.
    A note regarding the guide / slide bolts holding the calliper onto the car, they only require very little torque to do up. I wouldn't go past 30 Nm of torque. Don't over torque it as the bolt will easily strip.
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  3. #33
    Thanks very much, ill post if i have any issues... seems pretty easy, ill just take my time and be carefull...
    Thank you!
  4. #34
    Mar 2015
    Warner, QLD
    One more thing to note, brake fluid attract moisture. So don't leave the lid to the reservoir open while you are changing the pads.
  5. #35
    Thanks mate, got it done
    Not too hard after you know what your doing,
    Appreciate the help!
  6. #36
    Mar 2015
    Warner, QLD
    No worries did you enjoy the "bed in" process?
  7. #37
    May 2015
    Hi guys - I need new pads for a Mk7 GTI PP and looking at either the Remsa or EBC Redstuff pads. I am machining OEM rotors this time round.
    Any opinions on either of these pads ? I know the EBC Redstuff pads are ceramic but are supposed to still give good cold stopping performance - would like any advice on noise levels.
    I am in Brisbane and have only found Brakes Direct to supply.
  8. #38
    Dec 2008
    Sydney/Canberra
    If the discs are already lipped, I'd throw them away. By the time you machine the lip off, and skim the surface true again, they'll be pretty close to undersized. You get virtually zero tolerance with them, and Remsa pads will just trash them anyway.
    Can highly recommend ATE Ceramics, with ATE discs.
    You can get these from any one of 5 ATE Brake Centres around Brisbane.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  9. #39
    May 2015
    Quote Originally Posted by Umai Naa!! View Post
    Ok thanks - I'll see if I can find tolerance specs. The vehicle has done 20,000km. One track day (well... the driver) trashed the OEM pads.
  10. #40
    May 2015
    Rang ATE direct as the service centres in Brisbane wouldn't sell parts.
    Front rotors: $205+GST each
    Pads: $243+ GST set
    Over budget ! Any other recommendations ?
