Your turbo cannot stay on after engine shutdown. It is the engines exhaust that turns the turbo so without it, it will not stay running.
The sound your hearing is probably your radiator fans. The will stay on after the engine has been running to cool things down and I find they will stay on if your aircon is on also.
Dont worry about your temp needle so much, as long as its not in the red it should be fine and the temp will never move much once at operating levels.
If you have an engine light on your dash get it booked in and checked asap. It usually means somehing is wrong, not just a service.
Sent from my GT-I9100
MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
