Page 35 of 44 FirstFirst ... 253334353637 ... LastLast
Results 341 to 350 of 436
Thread: Audi S3 8P3 CustomCode Stage 2 PSS
  1. #341
    brisbane
    just checked it out, may be meet up in St. Kilda or Elwood. my number is still the same if you want to shoot a message nearer the time...
  2. #342
    Apr 2015
    Woodgate Beach QLD
    Quote Originally Posted by guile View Post
    You poms and the need for a pint
    Sent from my SM-G950F using Tapatalk
  3. #343
    brisbane
    the gf has no idea of the the size of an imperial pint, she thinks it is the equivalent to about 5 litres...
    i think thats because i say i'm just nipping out for a pint and come back 4 hours later absolutely maggot...
  4. #344
    brisbane
    PS where did you get your ce-lock from mate; i'm thinking about getting one for the m3...
  5. #345
    Apr 2015
    Woodgate Beach QLD
    You can have mine champ
  6. #346
    brisbane
    that would be awesome mate if you're sure thats ok. if i find i'm not using it much i'll pass it you back...
  7. #347
    brisbane
    bought some stickies, bit more used than expected but could be a good start to see what i think to them...
  8. #348
    brisbane
    so its taken agesssssss but the semis are finally on...
    not a big fan of the standard wheels and I'm sure they weigh a tonne so I'm on the hunt for a lighter set...
    also fitted this, safety first...
  9. #349
    brisbane
    the car still runs like a hairy goat when its hot so going to try changing the following before Saturdays happy laps...
    - spark plugs
    - coil packs
    - fuel bucket
    - g410 sensor
    - lpfp pump controller
    i'm also going to run the lpfp fuel pump adaptation via vcds. i know you shouldn't really change a lot of things at one go but i'm running out of time to find the cause of the issue so i decided to get stuck in...
    Fuel Pump Prerequisites:
    Ignition ON
    Engine ON
    System voltage at least 11.0 V.
    [Select]
    [01 - Engine]
    [Basic Settings - 04]
    Group 103
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    Wait until Field 4 shows "ADP. O.K.".
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Switch Ignition OFF.
    Note:
    Timing chain driven engines such as the CCTA, CBFA and CCTA were phased in during model year 2008. Those engines do not use a G410 (Low) Fuel Pressure Sensor so Basic Settings 103 is not applicable.
  10. #350
    Have you logged it hot mate? We see a lot of backing off by the ECUs due to heat, intake temps in particular.
    Would be good to log it all the time you are out on track if you can. Then hit the space bar to mark the file when you get a problem.
