Hi,
I recently bought premium expensive high quality license plate light- part no. 8K0052110.
Unfortunatelly, I was not careful and have not read that it is up to 2011 year manufacture of the car. I get error Number License Light on board computer +beep. In addition to this, I cannot switch off rear led lights- they are still on when ignition is on, even using daylight only. This started immediately after replacing license plate light.
I found various solutions to this and I find it will be best to DO NOT REMOVE light and add something(as it is very difficult to remove it withou damage + I prefer other solutions) but instead use coding.
I found that this might help:
module 09 (Central Electronics), byte 18, bit 0 Cold diagnosis License place lights active
or/and for golf mk6 I found out:
09-Cent Elect, Security Access: 31347, Adaptation
(1)-Leuchte25KZL HA59-Lasttyp 25 to new value of "43 - allgemeine LED"
(6)-Leuchte25KZL HA59-Dimmwert AB 25 to new value of "127"
Do you have any options that can work for Q5 09/2012 8R(not facelift)?
Thank you guys
