Results 1 to 3 of 3
Thread: Pre-sale mechanical check- should I be concerned?
    Oct 2005
    SE Queensland Hinterland
    Just had a Transporter checked over as a pre-sale inspection, this is the result, should I be worried?
    What is it worth?
    Chassis No. WV1ZZZ2DZ5H025983
    Make/Model VW LT35
    Engine: 2.5 diesel
    Speedo 211495
    - Slight oil leak from back of tappet cover area
    - Very slight oil leak from oil pump area
    - Front and rear brakes are new
    - Power steering very heavy, suspect pump or rack issue
    - Intercooler charge pressure hoses are leaking oil slightly on driver's side - Front anti-roll bar bushes have excessive wear
    - Battery - average - 56% life remaining
    - Brake fluid test failed
    - Serpent belt badly perished
    - All tyres are in good condition
    - No fault codes lodged in ECU
    - Last service stamped in book was at 163,417 kms on 26/09/2012
    - Timing belt and water pump are due for replacement by time
    Mk3 Golf Tdi about to sell
    Mk 1 Golf GLD somewhere in a paddock!
    Mk1 Golf Cabriolet
    MK2 Golf Turbo diesel engine and 5 sp gearbox
    Aug 2016
    NSW
    Yes.
    There are some immediate expenses there.
    Timing belt etc.
    2018 Crafter Runner
    T5.2 6sp manual.
    Feb 2019
    TR
    Hi sparkie;
    I used lt35 anj code engine 5 years.
    A chronic problem of fat leakage Lt35.
    Vey nice not having error code from ecu.
    You will receive a used vehicle.
    You Need to calculate and inspect the maintenance costs of the vehicle.
    You need to consider the financial situation.
    in this vehicle, how much of the oil packs in a while after you will still grease.
    Best regrads.
    SM-G610F cihazımdan Tapatalk kullanılarak gönderildi
