Results 1 to 8 of 8
Thread: 1.4 118kW v 1.8 118kW
    Skoda is offline Dubber
    Jan 2012
    Hi all,
    Just wondering what people think about the 1.4 Twincharged 118kW enigines in the Jetta/golf compared to the 1.8TSI 118kW engines in the Passat/Octavia.
    I was thinking that that the 1.4 might be smoother down low but might have to work harder and may not have the longevity.
    gldgti's Avatar
    gldgti is offline Super Moderator VWwA Super Moderator
    Gosford Central Coast NSW
    in the sydney mod section, The_Hawk has just posted his dyno plet from today with a 1.4TSI.http://www.vwwatercooled.org.au/foru...a-68365-4.html
    I would be fairly surprised if the 1.4 is smoother than the 1.8 - the nature of its makeup means that it requires boost to make torque, and that means a lot of technology has to work perfectly to get it to deliver smooth power.
    As a comparison, heres a dyno plot (same shop, very similar weather) from my old mk3 turbo diesel -
    quite similar numbers and rev-range to the 1.4, but see how my old diesel with greater displacement, only 2 valves per cylinder, sizeable turbocharger and mechanical fuel pump makes a much smoother torque curve because there are fewer feedback loops interacting with eachother (very simplistically). (just FIY, the 2 curves are so different because I increased fuelling after the first run)
    Definately the 1.4 has to work harder... not necessarily is that a bad thing though.
    '91 Cabby 1.9 TD - GT-15, FMIC, stainless 2.5" exhaust, Bilstein shocks, tuned injector pump, big nozzles, BIO-DIESEL
    '07 Octavia Kombi 1.9TDI - Audi Ronals, Eibach pro-kit, VIEZU tune, BIO-DIESEL
    Diesel_vert is offline Volkswagen Fanatic
    Jan 2009
    Quote Originally Posted by Skoda View Post
    I don't think it matters on a practicable level, and if you intend to do the sorts of mileages where it will matter, you'd be better off with the TDI anyway.
    Ryan_R is online now Supporter of VWWatercooled
    Apr 2010
    Get an ECU software update (i.e. APR Stage 1) and the 1.4L is a very fun little racing car to drive.
    0-100kph comes in about 6.8 seconds compared to 8.0 stock, similar to the GTI.
    118TSI Golf DSG
    gldgti's Avatar
    Probably the 1.4 is more economical than the 1.8 on the highway?
    Apr 2010
    I average 6.9l/100 although I don't drive like an old lady
    3-4 on the freeway (cruise control).
    118TSI Golf DSG
    Jan 2012
    Thanks for your thoughts.
    I know the torque for the 1.8lt TSI is 250, does anyone know what the 1.4lt is?
    Apr 2010
    240 stock, 320 with APR Stage 1 ECU software upgrade
    118TSI Golf DSG
