Results 1 to 3 of 3
Thread: Golf 6 R - Auto Headlights & Coming/Leaving Home - Not working
    Aug 2011
    St Kilda, VIC
    Hi All
    I am having some issues with the headlights, namely:
    1) The Xenon Headlights when set to Auto in the car - do not turn off even in bright daylight. They will stay on ALL the time no matter what. I have tested the sensor in Output Tests and it changes from 0-7 when driving into sun (7 being in direct sun) and it still says lights should be on.
    3) Lights turn off as soon as the ignition is off - no coming/leaving home lights (car switch in auto) and also do not turn on when car unlocked.
    I have plugged in my VCDS cable, and taken a scan, posted below. I have turned on coming and leaving home lights in the MDI and they appear selected in VCDS.
    There does appear to be an error with the light switch in the DTCs
    Your advice is much appreciated:
    Code:
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Component: Climatronic   H15 0709
       Revision: 00003001
       Coding: 0000001002
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_Climatronic A01006
       ROD: EV_ClimaAutoBasis_SE36.rod
       VCID: 7DDF2C51EC864AC904D-8028
    No fault code found.
    Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 46180A388825F1C040080080250008C445650088736D8960E48000040040
       VCID: 3851FD458B24AFE197B-806D
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 08101  26  0512
       Coding: 009795
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 231010 05  54  0403
       Coding: 012BAD
       Subsystem 3 - Part No: 1K8 951 171
       Component: DWA-Sensor 00  001 0104
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
    1 Fault Found:
    01800 - Light Switch (E1)
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 3
                        Fault Frequency: 8
                        Reset counter: 137
                        Mileage: 45313 km
                        Time Indication: 0
                        Date: 2014.11.02
                        Time: 18:25:33
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            Term 50 Off
                            OFF
                            OFF
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5K0 919 475 D    HW: 5K0 919 475
       Component: PARKHILFE 8K  H07 0010
       Revision: --------    Serial number: 48341022200738
       Coding: 100104
       VCID: 3753FE79863AA0999E1-8062
    Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRAEJMVW
       Coding: 00003131
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
       ROD: EV_AirbaVW10SMEVW360_SK35.rod
       VCID: 3B5BE249B21284F97A9-806E
       Crash sensor for side airbag; driver side:
       Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Fahr.V  H01 ----
       Serial number: 3572MSME14554159ZZZR
       Crash sensor for side airbag; front passenger side:
       Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Beif.V  H01 ----
       Serial number: 3582MSME374C2155ZZZX
       Crash sensor for side airbag; rear; driver side:
       Component: S.Sens.Fahr.H  --- ----
       Serial number: 3512QSME3E136B4AZZZ0
       Crash sensor for side airbag; rear; passenger side:
       Component: S.Sens.Beif.H  --- ----
       Serial number: 3522QSME263A6B7BZZZ5
    Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90440JJI001OL
       Coding: 1892140000
       ASAM Dataset: EV_SMLSNGKUDS A05001
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 76CD337DC9B01991457-8023
       Multi Function Steering Wheel Control Module:
       Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H06 0010
       Serial number: 0161954
       Coding: 830000
    Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
       Part No SW: 5K6 920 871 B    HW: 5K6 920 871 B
       Component: KOMBI         H20 0420
       Serial number: 00000000000000
       Coding: 170F01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
       ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
       VCID: 334BCA699A424CB9A29-8066
    Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 251010F2003377
       Coding: EDA37F0600060200000003
       VCID: 6DFF1C1174E6DA49B4D-8038
    Address 22: AWD        Labels: Redir Fail!
       Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
       Component: Haldex 4Motion      3017
       Coding: 0000005
       Shop #: WSC 00000 000 00000
       VCID: 44A999B507ECFB010B3-8011
    Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H20 0420
       Coding: 000000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
       ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
       VCID: 6AF5170D8D08CD71D1F-803F
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
       Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
       Component: Tuer-SG         009 2120
       Coding: 0000692
       VCID: 3147C061A85E7EA9D05-8064
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 74     3001
       Revision: 00H17000
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
       Component: Tuer-SG         009 2152
       Coding: 0000948
       VCID: 354FF4715C3652898CD-8060
    Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
       Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
       Component: AFS-Steuergeraet    0148
       Revision: 00H04000    Serial number:
       Coding: 1475932
       VCID: 3449C975574C4B81BB3-8061
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Subsystem 2 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul r    0004
       Coding: 00000022
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5K0 035 190     HW: 5K0 035 190
       Component: Radio RCD510  041 0167
       Revision: 00000001    Serial number: VWZ1Z3K3572072
       Coding: 0500000001
       VCID: 62E57F2D7D38953119F-8037
    MkV (2007) Golf R32 | Black | Fully Standard - For now!
    Nov 2014
    Poland
    Are You sure, the E1 switch pin 2 is connected to the BCM A20 ?
    Aug 2011
    St Kilda, VIC
    Just to let everyone know this is fixed was just a coding mistake!! Thanks to some help from good people on the forums, sorted it out
