Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Closing power tail gate in Superb via middle console?
    Dec 2017
    QLD Australia
    Activate and see ?
    Dec 2010
    Quote Originally Posted by Blackpaladin67 View Post
    Activate and see ?
    I tried it last night, but I'm not sure if maybe I'm barking up the wrong tree. I was able to set the following in the Arteon:
    Verdecksteuergeraet-Kick_and_close = Installed
    Byte9_VIP-Coding_kick and_close_function = Active
    But it didn't change anything.
    The reason I'm not sure if this is the right setting is because there's no German -> English translation word (that I can find on Google) for "Verdecksteuergeraet". And when I search for that word on Google, it shows me a hardware module for convertible cars. So I *think* this might be related to "kick to close" for soft tops/convertibles.
    But our Superb isn't convertible, a soft top, or has a sunroof.
    Interesting, the 6D-Trunk Electrics adaptions between the Arteon and the Superb are pretty much identical. The only difference is how far things open, minimum height etc.
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
    Dec 2017
    QLD Australia
    Quote Originally Posted by DreamensioN View Post
    Maybe a Audi thing ?
    Jul 2010
    maybe there is some sort of hardware or module that needs to be "installed" or present for the coding to actually work.
    though it doesn't make sense for different hardware between kick-to-close and kick-to-open!!
    could there be differences between the Wagon and the Liftback? cause technically urs would b aligned to Superb Liftback as opposed to a Superb Wagon in terms of parameters of the power tailgate.
    maybe there are differences beween SW and HW components?
    below is from my VCDS scan:-
    Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
    Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
    Component: HDSG-Modul H13 0261
    Revision: -------- Serial number: 31249117700000
    Coding: 1008
    Shop #: WSC 33361 790 00141
    ASAM Dataset: EV_DeckLidCONTIAU736 001014
    ROD: EV_DeckLidCONTIAU736_VW37.rod
    VCID: 4188CC78D0EACA4AF3-8014
    No fault code found.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Dec 2010
    Quote Originally Posted by dArK5HaD0w View Post
    Coding: 1008
    Ok this is interesting... your component (HDSG-Modul H13 0261) is the same as the Superb Wagon & Arteon. Here is my wife's VCDS scan.
    Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
    Revision: -------- Serial number: 31555519500000
    Coding: 0D88
    Shop #: WSC 55987 002 1048576
    ROD: EV_DeckLidCONTIAU736_VW27.rod
    VCID: 41CAB44BD064A44C57-8014
    This is my scan from the Arteon - it looks almost the same.
    Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
    Component: HDSG-Modul H12 0261
    Revision: -------- Serial number: 31537933200000
    Coding: 0B28
    Shop #: WSC 00015 115 08193
    VCID: 42C8BB47D562BF544E-8016
    I've gone through the 05-Acc/Start Auth, 09-Cent. Elect and 6D-Trunk Elect. adaptations line by line between the Superb and the Arteon with the only real differences (that may be related to the tailgate closing) being those settings I mentioned. The module and the kick_to_close function.
    I may need to ask on the Ross Tech forums.
    My car: MY18 Arteon
    Jul 2010
    so the HW and SW revisions are different between the Superb and Arteon:-
    Superb - Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
    Arteon - Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
    i also notice the coding on ur wife's Superb is 0D88, while mine is 1008 - despite having the same HW and SW revisions.
    Apr 2016
    Clayton
    Sorry, anyone try this with OBD11? please share. Thanks.
    I can see the link from VCDS but I am not sure if the same or not.
    note: currently by default my Superb III able to use the key fob to close and open. Close using key fob inside the car from driver seat a bit of a challenge. Need to point at the back.
    Thanks
    Apr 2016
    Clayton
    Jul 2010
    with the Superb, it depends on what controller the car has, and even still it's a hit or miss.
    and if its a hit, ur more likely to see errors being logged.
    u also need a VCP tool. VCDS or OBD11 won't do it.
    u can code it for the Octavia, via VCDS/OBD11.
    the Kodiaq does it from factory.
